Alight guys, here are our trackdays for January 2012:
Wakefield:
8th - drift day
9th - Speed of the Streets
10th - Speed of the Streets
11th - Speed of the Streets
12th - Speed of the Streets
16th - Speed of the Streets
17th - Speed of the Streets
18th - Speed of the Streets
19th - Speed of the Streets
21st - Speed of the Streets
24th - Speed of the Streets
25th - Speed of the Streets
28th - Speed of the Streets
30th - Speed of the Streets
31st - Speed of the Streets
Marulan Driver Training Centre:
11th - Street Car Day
13th - Street Car Day
15th - Street Car Day
22nd - Street Car Day
23rd - Street Car Day
Im sure there is some days at eastern creek too, but i havent looked these up yet...
So as you can see there is plenty of track time for January! Hope you can get some time off work and i might see you there...i'm hoping to make a good chunk of these!
https://www.sau.com.au/forums/topic/386460-general-trackdays-in-jan-2012/
wow, thats a lot of speed days! No one booked in for Jan at all?!
lol maybe it is even slower than Dec bookings...they gave the club a good deal for the Dec day.
Can someone convince Neil to take Cheryl to Marulan in late Jan?
If he takes Cheryl... I'll look at taking the Coon out...
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
