alright out of the two which one you guys recommenned ??
i heard with the blitz one you can set a "high boost" button......
can this be done with the apexi ??
cause i would prefer to get the avcr as it goes with my turbo timer....silver with blue backlit.....and also i plan to get power fc....so im thinking the avcr would be more compatible with it....
can i get some comments on people how have either of them installed ?
cheers....
https://www.sau.com.au/forums/topic/38647-blitz-id-3-vs-apexi-avc-r/
you might not like this but it's my experience..... I didn't have an avcr but I had the boost controller that goes with power fc, which uses the same solenoid as avcr. Ever since I put it in I had problems... fluttering boost... power loss etc.
I went to croydon and they said the boost controller would be my problem so I did a lot of reading up about it and found that these solenoids are prone to this kind of problem and has problems with the wastegate (hence the boost flutter).
Changed it to a Blitz Dual SBC Spec R about a month ago and instantly my car was much better....
You may be lucky and never experience any of these problems... I hope for your sake you are lucky.
hehe madd ill take you up on that...ill prob go to tha sau dinner thing on 29th is it ??
you can tune it for me then !! hehe...
hmmm.....now this is making me paranoid....cause my mechanic warned me about this...he was saying they both have the same performance but the apexi ones sometimes have issues.....and he said the blitz is easier to use...and its $50 cheaper too ! hehe...
but hey frank seems to have gotten a lot of use out of one avcr........
just hope i can do the same...
yeah the only thing i didnt like about the blitz one was that it looks empty with just the boost controller by itself...cause its designed and shaped to go with the Power id......
can a "high boost" button be set up with the avcr ???
cause so far i read the id3 and the profec B-spec 2 both have that function..
avc-r has 3 settings. boost: you can have boost "OFF" which means it runs standard boost.
Setting "A" which you could set up for high boost and setting "B" which could be for low boost
I run "high boost" all the time, if I don't want to go as fast, I don't push the throttle pedal down so far. Honestly I see no advantage in multiple boost settings, I would be afraid of getting caught on "low boost" at the wrong time.
