Hey guys,
got a couple of things im trying to get rid off to fund my build.. Parts are off my Gtt and a r32 Gtr head..
1) Standard Gtr camshafts $100
2) Standard Gtr Cam Gears $50
3) R34 Steering wheel $120
4) Optima yellow top battery $210
5) R34 Coupe Rear seats $100
6) R34 rear quarter plastic trims $100
7) R34 front guards (white will not separate) $400
8) R34 series 1 front bar (really bad paint) $free
9) R34 Interior carpet (has wholes due to roll cage in the back) $100
10) R34 Rear parcel shelf $40
11) R34 Boot Carpet $50
12) Stock arms (castor rods, camber,..) $40 Each
13) Stock Air box with snorkel $160
14) Stock boost solenoid $20
15) Stock dump pipe and front pipe $40
16) R34 Radiator $50
Happy to ship all items at buyers expense.
Please send me a msg for pics and il take some on request..
Located in Mordialloc VIC
Please pm or sms during bus hrs on 0432647023
Cheers
Herb
  • Replies 41
18) R34 Gtt Bonnet Hinges $50
19) R34 Gtr-Gtt Bonnet Latch $50
20) R34 Spare Tyre $50
21) R34 Passenger Kick panel with flare and bracket $100
22) R34 Rear Seat Belts $70
23) R34 Std Cat Converter $20
24) R34 std dump and front pipe $50
25) R34 Auto Cluster with around 120,000 kms from memory $100
26) R34 std gauges $50
Cheers
Herb
Hey guys,
3) R34 Steering wheel $120 $100
7) R34 front guards (white will not separate) $400 $370
Cheers
Herb
Edited by GTXR34
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
