Jap_Muscle Posted December 25, 2011 Share Posted December 25, 2011 (edited) Hi Guys, Over the past few months my car has suffered from a extremely annoying situation where the car cabin starts to heat up alot and more then often, forces me to blast the AC on to have it bareable. Ive double checked its not my heater that is stuck on or anything like that. It seems the source of the heat is coming from under the gear boot. I pulled it apart and this is what i see. About 8months back i had my mech install a Short shifter, however im not quite sure but i recall there being insulation around the boot. Can anyone confirm this? Edited December 25, 2011 by Jap_Muscle Link to comment https://www.sau.com.au/forums/topic/386521-do-you-guys-have-insulation-under-gearboot/ Share on other sites More sharing options...
Hanaldo Posted December 25, 2011 Share Posted December 25, 2011 Hi Guys, Over the past few months my car has suffered from a extremely annoying situation where the car cabin starts to heat up alot and more then often, forces me to blast the AC on to have it bareable. Ive double checked its not my heater that is stuck on or anything like that. It seems the source of the heat is coming from under the gear boot. I pulled it apart and this is what i see. About 8months back i had my mech install a Short shifter, however im not quite sure but i recall there being insulation around the boot. Can anyone confirm this? Yes, I've got a small piece of insulation material that sits in there. Link to comment https://www.sau.com.au/forums/topic/386521-do-you-guys-have-insulation-under-gearboot/#findComment-6165097 Share on other sites More sharing options...
Jap_Muscle Posted December 25, 2011 Author Share Posted December 25, 2011 thought so. i dont suppose it will be any diffeerent if i just went out and bought some regular house insulation and placed it in the same spot? Link to comment https://www.sau.com.au/forums/topic/386521-do-you-guys-have-insulation-under-gearboot/#findComment-6165160 Share on other sites More sharing options...
89CAL Posted December 25, 2011 Share Posted December 25, 2011 the top of the boot isnt holding onto the shifter, so there is an air gap letting hot air up through there. I made my own short shifter and just pulled the boot down a bit and cable tied the boot tight against the shifter (used 2 cable ties actually) I had a second boot underneath the one you can see in that picture but it was pulling my shifter out of first (not sure why...) so I just got rid of it. I have no heat issues at all from that area of the car. Bit noisey, but then again I do have polyurethene bushes on the gearbox and diff now Link to comment https://www.sau.com.au/forums/topic/386521-do-you-guys-have-insulation-under-gearboot/#findComment-6165190 Share on other sites More sharing options...
EJD001 Posted December 25, 2011 Share Posted December 25, 2011 took mine out when i did my short shifter!! Link to comment https://www.sau.com.au/forums/topic/386521-do-you-guys-have-insulation-under-gearboot/#findComment-6165200 Share on other sites More sharing options...
Jap_Muscle Posted December 25, 2011 Author Share Posted December 25, 2011 Do you get alot of heat coming from under it? Link to comment https://www.sau.com.au/forums/topic/386521-do-you-guys-have-insulation-under-gearboot/#findComment-6165207 Share on other sites More sharing options...
Jap_Muscle Posted December 25, 2011 Author Share Posted December 25, 2011 the top of the boot isnt holding onto the shifter, so there is an air gap letting hot air up through there. I made my own short shifter and just pulled the boot down a bit and cable tied the boot tight against the shifter (used 2 cable ties actually) I had a second boot underneath the one you can see in that picture but it was pulling my shifter out of first (not sure why...) so I just got rid of it. I have no heat issues at all from that area of the car. Bit noisey, but then again I do have polyurethene bushes on the gearbox and diff now Thanks for that mate, ill try tightening it up. hopefully that fixes it. Link to comment https://www.sau.com.au/forums/topic/386521-do-you-guys-have-insulation-under-gearboot/#findComment-6165219 Share on other sites More sharing options...
