Full comp ain't a guarantee of happy times in this scenario. Many excesses are about the same cost as the repairs and the repairs aren't quite enough to write off the car :/
  • Replies 67
Posted Images
Watch out with some insurance companies. My wife's car got damaged in the last big storm and had rating 1 full comp. They repaired the car and then dropped her to rating 3 and increased her yearly premium by more than 60%. We changed companies and got rating 1 and ended up saving almost $200 a year compared to previous rating 1 policy anyway. Win for us.
^ wtf? how does that work? an 'act of god or nature' or whatever, and she loses ratings and premium goes up?? how has she suddenly become a riskier driver as isn't that what the rating/premium change is ultimately suggesting (probabilities etc?)
if people are looking for a dent person, Mr Dent (Vince) does fantastic work. Originally recommended to me by Damian @ Final Inspection. If you google it, you'll find his number (no website)
I live in Roxy, literally 5 mins from Cragieburn station. No hail :laugh:
If ther was hektic hail my old man wouldve skitzed it :O i garaged my skyline instead of his merc for induction pipe making. i shit my pants when i heard hail was coming.
lucky tho :D
dodgy assholes... insurance companies are just greedy f**ks who want to drain people's money. talk about trying to recover their losses. excellent work changing companies :D should have faxed them a note with their letter of increase telling them to shove it up their ass.
45 minutes on hold and answered
covered by full comp
no need to shop around for quotes, they have setup an assessment place which will call me before the end of the week
ill take the car there, they will check it and decide wether to proceed with quotes/pricing or write it off (usually its the other way around)
he said the roof is the main concern if it has lots of deep dints, they have to take the roof off, which becomes an economical write off
so early stages
but very positive outcome from just car insurance
very helpful, quick to help
no blah blah your not covered rubbish
excess is 1k
as for williamstown, there was hail but like pea sized hail. Had some family there during the storms and they were caught out but i had a good look over the cars and didn't see anything, so williamstown would be ok i would think. no big hail
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
