When you say killed - has the element broken? Have you tried cleaning it - resoldering the joints -= checking the wires to the plug? Have you replaced it with other second hand ones or a new one?
they were replaced with genuine nissan air flow and its happened again.
thanks
https://www.sau.com.au/forums/topic/386546-airflow-meter/#findComment-6165382
Electrical contact cleaner will clean the element of the AFM.
How has it been determined that you have killed the AFM?
the last two were while my wife drove it, and the car would cut out our mechanic said it would be the afm, pull the plug out and take it to him.
then on the way back from the airport xmas night the car was just on boost i went to kick back to change lanes then it did the same thing my wife said.
any you guys have had a z32 afm im told there better ?:huh:
https://www.sau.com.au/forums/topic/386546-airflow-meter/#findComment-6165964
The Z32 has different resolution but is not better.
I still don't understand how you have "killed" the afm. Sure they can get dirty, sure they can have dry soldered joints, sure you can have a wiring issue at the plug but having them fail outright is a bit of a long shot on a relatively new car. You need to find the actual cause.
I have repaired three afm's with dry solder (but much older units that you are using) and have always given the elements a tickle with contact cleaner as a part of routine maintenance.
https://www.sau.com.au/forums/topic/386546-airflow-meter/#findComment-6166023
Ours cant be repaired Wolverine, as far as I know. I pulled one apart and found surface mount processors etc inside them but no dry solder joints. They just seem to die for no reason, although touch wood I havent blown one yet. Are you sure they were genuine Rudi?
To run a z32 you would need to tune your car with an Emanage Ultimate or a Fcon Vpro and modify the wiring and piping to fit it. Did your mechanic explain to you that they cant just be swapped?
https://www.sau.com.au/forums/topic/386546-airflow-meter/#findComment-6166094
The board is potted with some sort of gel, even water wouldnt damage it I would have thought. Perhaps the supply voltage is a little too high? No idea really.
There are a few different types though, perhaps the older ones had issues and were replaced by better ones?
I would try the error codes to make sure, there are many reasons for them to go into limp mode like the brake wire cut mod and throttle motor issues... Perhaps try resetting the ecu properly first?
https://www.sau.com.au/forums/topic/386546-airflow-meter/#findComment-6166234
thanks to all for your help hope to go to car doctor tommorow for check up, will keep you posted on results.:thanks:
https://www.sau.com.au/forums/topic/386546-airflow-meter/#findComment-6166244
Yep.
Original part number was 22680-6N211 for the sensor itself which was used on 02-03 Elgrande (VQ35de), all M35's, 01-03 P12 Primera, 01-04 V35's (NOT VQ35de) and 03-06 VQ30det powered F50 Cima's.
This was changed to 22680-6N21A in Dec 2006 which was only used on the F50 Cima VQ30det thereafter.
Interestingly, the sensor used for just about all other Nissan's (including T30 Xtrail, J31 Maxima, Z33 350z, VQ35de powered V35's, V36 Skyline and PM35 Stagea) is 22680-7S000.
https://www.sau.com.au/forums/topic/386546-airflow-meter/#findComment-6166314
6N211 is the number that comes up for the sensor if you go through FAST.
There is a second number to left on the part numbers table which is the updated part number (so 6N21A in this instance).
I don't have a screen shot as I am on the wrong computer, but most Nissan dealerships state the default part number and their system automatically updates the part number for the order.
https://www.sau.com.au/forums/topic/386546-airflow-meter/#findComment-6166613
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
