posting for mate
fresh s2 rb25 with 78 tho kms
gates racing belt
gmb water pump
brand new thermostat
brand new radiator all new hose under intet manifold
respray 2 years ago paint is mint part from front guards from flaring out to fit wheels
avs model 5 wheels 17x8 19x9s
brand new kumho ku36 front tyres 200 each
come with 2 pairs half tread 17s for rear
interiour still complete
just mechined brake rotors
extreame hevy duty clutch
hdi front mount intercooler
gtr rear spoiler
extened front lcas 30 mm
30mm front bolt on spacers
brand new hard tie rods with built in 6mm spacers
brand new longer tie rod ends
au coil pack conversion 2 months ago new coil pack leads plugs
boost and water themp gadges
shimed diff with come with standerd lsd in the boot
full 3 inc exhaust with twin flutes out the back
lots of spares with the car
comes with front caster arms yet to be fitted
car was borght 6 months ago standard all mods been done in the last 2 months
did the last drift prac of the year and decided it wasnt for me
only ever run on 7 psi
quick sale 4 grand
txt or call 0430989822
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
