Hey guys
So I got a Greddy Profec 2 for Christmas off the partner and its proving to be a pain to setup.
I ended up tapping into the vac line that the stock gauge uses (dont know if this is an issue)
Right now it seems to not want to go over 6psi
If anyone knows anything about these then let me know.
Settings I currently have it set to.
SET: 35%
GAIN: 5%
SET GAIN (start boost): 7psi
WARNING: 11psi
LIMITER: 5%
I think there might be a vac leak because when I pull the line off the nipple on the intercooling piping that goes to the solinode and the VAC on my gauge does not change a bit.
On idle sites around probably 20 or so
This makes me think there is already a big enough vac leak that by me doing this does not cause any issues
Here is a picture of what my VAC looks like when coming off throttle. (very bad)
Scrarching my head - so u connected it to the boost gauge sensor? Or the stock boost solenoid near the turbo?
U need to run it from the cooler pipe to the NEW boost controller solenoid then to the wastegate.
Then T into a vacuum/boost source such as the stock boost gauge sensor on firewall and run that one into the cabin into the boost controller
Haha nah sorry
The controller is hooked up to the actuator and the nipple on the cooler piping. All correct.
But my gauge sits at around -20 VAC
When I pull the line off the intercooler piping the VAC does not change is that normal? Or should the vac drop because it's got now an exposed nipple on the intercooler piping?
It also sounds like a sewing machine on boost which leads me to believe its defiantly got a leak somewhere.
But one question as well is for the boost gauge part of the profec I pulled the hose off from the stock vacuume line where it enters the air intake and ran a hose straight to my profec. Is that okay to do?
Can u post up a pic of the vacuum line ur talking about?
The cooler pipe line is before the throttle body so it wint really affect ur gauge reading after the throttle body. If that makes sense?
What do u mean by a sewing machine?
Try upping the gain to 15, set the boost warning to 15psi.
Watch the boost gauge and see if it holds flat or if it oscillates up and down
I will take a pic tomorrow of the vac line it comes out of the back of the intake manifold and normally goes to the stock gauge inside the car. Instead I pulled it off and ran my own pipe from it to my gauge in the car
Just has a sewing machine noise hard to describe but as it spools it has a noise like a sewing machine lol
My phone network is down so I cant get pics.
Right now I fiddled with the setup and the T now goes into the fuel regulator VAC line
I put the stock gauge VAC line back onto the back of the intake manifold.
Anyone know of a simple technique to find a VAC leak?
I tried spraying the hoses with "start ya bastered" to see if I could hear a change in revs but I cant find it
When coming off WOT the gauge shows -30 VAC and the Greddy unti shows -99 VAC
Both of which are the lowest numbers they can display
. It won't, I believe this part is under mild pressure at idle. Pull a vac line off after the throttle plate and see if the idle changes.
u sure it's not just the boost controller solenoid clicking away, they can be pretty loud.
I pull hoses off and it does not really change so the VAC at -30 is pretty normal?
I think I had it the wrong way around I was thinking your vac went lower when you had a VAC leak.
So if I had a leak I would expect the number to increas to say -20?
the ticking might be the solenoid then I guess because I have never had one I always used the boost T.
yes its normal to drop lower when you come off WOT, -30 in that case would be fine
you really need to show us how its been hooked up from where to where.
have you tried upping the boost or what? make sure you have the solenoid hooked up right too in terms of in and out
I wish I could get a photo but as I said I am with vodafone so nothing is working haha
The car is running great though.
Boost is tuned for 8psi and 10psi for 2 settings.
It all seems to be running fine now guys
When I get back from the coast I will post up some pictures
