  • Replies 45
From what i gather it would be a bad idea due to thermal expansion, different materials expand at different rates, example: ally head, iron block and stainless head gasket. Theres a lot of heat in the combustion chambers
Matching oil drains and water jackets on block and head to head gasket, yeah go for it
but matching the gasket to the block cylinders is a bad idea, (bores need to be straight no taper no ovality) yes it has a chamfer on top of the bores, but they're only purpose is to help get the rings in during assembly
matching the chamber to gasket, enlarging the chamber, removing both squish pads will reduce the quench (when the flat spot of both piston and head meet in pushes the last of the volume into the combustion area for a more "complete" burn) removing the intake squish pad has been done a fair bit but you will find there is still material between the chamber and gasket
then there is the extra volume that was just added, can you garantee that you haven't reduced the compression ratio dramatically?
Removing all that material will put extra strain on the firing ring on the head gasket, all the material being removed up to the firing ring will encourage the gases to escape, consistently blowing head gasket
To V8tzr: I definately dont reommend matching the head to the head gasket, but if u want to build yourself a better engine, after the block has been bored/honed or is in ready to assemble stage bolt the ead on WITHOUT a head gasket and install all bolts (if using studs make sure theyre all installed and use 6 nuts with washers on front 2 rear2 and centre 2 studs) only needs to be firmly tightened DONT torque to specs!, Also make sure both DOWELS are in the block. get a long scribe thats very pointed and sharp and mark the parts of the head that over-hang, dont worry abt the flat squish pads but more on the outer most diameter areas. The bigger the bore is from STD the more this area becomes an issue. Like ive mentioned if done correctly you WILL be able to make more power than if u dont do it. Cheers
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
