Hey, Few items im wanting to sell
Nismo 740cc injectors, top feed, 6x injectors, 100km old $850
R34 GTR wheels: 4x wheels, 18x9 +30, Minor scuff marks on outer lip $1700
SSR mesh wheels: 2x 17x9 +22 $450 Pair 4x114x3 PCD NO TYRES
2x 15x9 +19 $350 Pair 4x114x3 PCD 195/65 tyres
Rota Rbx wheels: 4x 18x9 +30 Very good condition $800 4x114x3 PCD
SSR Professors: 2x 18x10 +32 & 2x 18x9 +35 very good condition $2000 4x114x3 PCD
SSR Professors: 2x 18x10 +10, Wicked dish, near new falken FK452 tyres, 245/40 $1800 4x114x3 PCD
SSR Professors: 2x 17x9 +22 $1000 4x114x3 PCD
Or I can sell a staggard set of the 2x18x10 +10 & the 2x 17x9 +22 for $2500 (so 4 wheels) 4x114x3 PCD
Works wheels, Brand new still wrapped, Staggard set, 2x 18x9.5 +20 & 2x 17x9 +17 5x114x3 PCD..WILL DECIDE PRICE SHORTLY
VE commodore special international edition,18". only 2500kms old, bridgestone potenza tyres 245/45 $1200
S15 standard alloy wheels, 16x6.5 5x114x3 PCD... PRICE SOON
Audi S3 sports alloy wheels, 18x7.5 only 2000kms old $800
Haltech E11V12 Ecu, Pug & play, Patch loomed for an Rb25 $800
S13 silvia rear bars x2, Vertex style, $100 each
180sx standard rear bar PRICE SOON
S13 standard front bar PRICE SOON
180sx/s13 rear sub box that molds around your strut towers (sub included) PRICE SOON
Bride copy seat PRICE SOON
Tein NA suspension, Will find out what they suit shortly PRICE SOON
I still have a few more items I need to list, I will update this space within the next few days, So keep an eye out
I can post any item at your cost, If your local, I can also deliver
Please contact me on 0419525562
https://www.sau.com.au/forums/topic/386629-wheels-ecu-injectors-seats-etc/
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
