  • Replies 42
It means it was, from factory, a Non Turbo car.
Now that means the person you bought it from, who told you it was an "EX-Turbo" had gone and turbo'ed a non turbo car, then removed it all and sold it as stock non turbo again.
This isn't as bad as a Turbo car that had been neutered of its turbo and running low compression.
You do not have a 25GT-V but you do have a 25GT. Still, that's good news for you. thumbsup.gif
More likely it means the seller didn't know what they were talking about. Probably thought that all Skylines are turbocharged so this one must have been deturboed.
That's what I'm thinking too. But then again, some the habibs and morons out there would be stupid enough to go to the trouble of turboing an NA and unturboing it.. lol..
I'm thinking the same as you though Hanaldo. It's probably just a factory non turbo stock as a rock. They hype it up to people who know nothing about cars by slipping that magical word in. 'turbo'
Very nice, & welcome !
Love the Nismo front bar - looks very very nice with the wheels, in blue.
If you get sick of the wheels one day down the track simply powdercoat them white, would look even better IMO & is pretty cheap to do.
R34 Nismo-kit side skirts arnt expensive, if you can find them, & would finish off the 'looks' very nicely.
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
    • It will be salvageable. It really doesn't matter what is damaged. Opening up a 30+ year old motor for a rebuild immediately means a complete rebuild of the head anyway. Damaged valves just means an opportunity to put in some nice new ones. And in the modern day, why would you not throw at least a nice set of pistons at something. And if you're doing that, why not rods, and ARP fasteners, and so on.
