The car is in perfect condition & has been pampered its whole life with regular details & polishes every 2 months. The car has been serviced every 4000kms as well as the major 100k service done 2,000kms ago.
Is running a very respectable 300rwkw @ 19psi
Performance Modifications:
Z32 Nistune ECU (better over R32 as can keep VCT control)
Drift Pod Filter (in aftermarket air box with cold air intake feed)
Z32 Air-Flow Meter
Blue Silicone Induction pipe
ATS High-Flow Garrett GT3071 Ball Bearing Turbo
HDI GT2 Spec Intercooler With 2.5" Piping
Turbosmart Silicone Joiner & Heavy Duty T-Bolt Clamps
Turbosmart Silicone Vacuum Lines Throughout
Turbosmart eBoost 2 Electric Boost Controller (set @ 10psi low & 19psi high)
Turbosmart Dual Port BOV (vented to atmosphere)
Walbro High-Flow Intank Fuel Pump
Braided Fuel Hoses
Deatschwerk 550cc Injectors
Tomei Pon Cams (256 degree duration & 8.5mm lift both inlet & exhaust sides)
Drift Oil Catch Can (speed-flow fittings & -12 braided hoses)
Oil Cooler with Oil Filter Relocation (all braided hosing)
Drift High-Flow Magnetic Oil Filter
Splitfire Coil packs
NGK Copper Spark Plugs
3" Front/Dump Pipe
3" De-cat Pipe
3.5" Cat-Back Exhaust
Twin 3" Rear Straight Pipes
Xtreme HD Motorsport Clutch
Nismo Short Shifter
Cusco 1.5 way LSD with 4.11 diff gears
Other Engine Parts:
Turbosmart Oil Filler Cap
Gates Racing Timing Belt
HPi Clear Timing Belt Cover
Gates Racing A/C & Alt Belts
Gates Racing Radiator Hoses
Nismo 1.2 Bar Radiator Cap
Blitz 40mm Aluminium Racing Radiator (with radiator air-guide cover)
Mines Racing Japan Turbo Blanket
Many More.....
Handling:
Nismo Front Strut Brace
Factory Rear Strut Brace
Nismo Master-Cylinder Brake Stopper
J's Racing Engine Torque Damper
Tein Coilovers (fully adjustable)
Bendix Semi-Racing Brake Pads (front & rear)
DBA Semi-Racing Slotted Brake Rotors (front & rear)
17x8 +25 & 17x9 +30 Sparco Racing Lightweight Racing Rims
New Nismo Engine + Nismo Trans & Nolthane diff mounts
New Nolthane Bushings throughout
Interior:
JVC CD Player With USB Connection
6.5" Alpine Type-R Front Components
6" JL Rear Speakers
Kicker 350w 4-Channel Amp
Pioneer 1000w Champion Subwoofer
Pioneer 750w Mono-Block Amp
Autometer 20psi Boost/Vacuum Gauge
Factory Optioned 40th Anniversary Nismo 300km Speedo Cluster
Momo 320mm 4" Dished Suede Steering Wheel
Blue Underdash Neon’s
Nismo Aluminium Foots Pedals
Nismo Floor Mats
Recaro SR3 Reclinable Bucket Seats (drivers & passengers)
Leather Covered Rear Seats
Many More....
Exterior:
Nismo 400R Front Bar & Side Skirts
SRI Circuit Attack Carbon Fibre Canards
R33 GTR Rear Bar Pods
Nismo R34 GTR Z-Tune Carbon Fibre Bonnet
R33 GTR Adjustable Spoiler
Nismo 400R Carbon Fibre Spoiler Blade
H.I.D 6000k Head Lights
Nismo Clear Side Indicators
L.E.D Tail Lights
The car has 3 months registration, and is the perfect street/track/drift car. Never taken to the track but will be very well suited.
$20,000
Car is advertised elsewhere. No low offers, not in a rush to sell. Car performs very well and is a real head turner whenever driven.
Please contact on 0434 052 990 :thanks:
https://www.sau.com.au/forums/topic/386638-300-kw-r33-skyline-40th-anniversary/
