nik. Posted December 27, 2011 Share Posted December 27, 2011 (edited) hey guys, parting out my r33 s1. will get pics of items up tomorrow!! or sms 0416 129 811 for pics complete standard rb25det package minus turbo from a s1 r33. purchased as low km import engine and installed by justjap on 11/12/09 (2 years ago) and has since put 31,000km on the engine. I also have the purchase and install receipt from justjap. includes throttle body, intake manifold, injectors, rail, reg, complete running motor with accessories; alternator, exhaust manifold, coilpacks and ignitor, loom and standard ECU with heavy duty clutch ( unsure of what the clutch is, i havnt split the box and engine yet ) Engine runs fine with no issues, blows no smoke. $850!! this has been for sale for 6+ months and i havn't had much interest so just want it gone tomei brake master cylinder stopper $60 HPI jap brand intercooler kit with complete piping ( hot pipe and cold pipe, from turbo to throttle body ) scilicon joiners and clamps suit r33. (possibly other r chassis?). core size 600x300x75, tube and fin. used for less then 3,000km. $400 r33 s1 dash, excellent condition. no cracks $80 r33 s1 dash cluster, displaying 211,xxx km. fully functional, no faults. $60 r33 dash, air vent & din surround $40 digital climate control unit $80 passenger side door skin $30 driver side door skin $30 driver side window control, fully functional. all buttons work perfectly $40 passenger side window control, fully functional. all buttons work perfectly $30 passenger side door complete, with window, motor, loom, door handle etc only missing the door skin $90 driver side door complete, with window, motor, loom, door handle etc only missing the door skin $90 left + right side oem electric mirrors $60 r33 rear subframe with traction & camber arms, hicas rack with toe arms and ends all still attached. No diff and no lca's $150 front crossmember with steering rack & tie rods and ends still attached ( ends in good condition, with unripped boots) , ps pump and all lines also attached. $180 oem front castor rods with recently replaced bushes $50 front castor rod brackets, straight, has taken no hits $40 RHS headlight, good condition. no cracks, no mounting tabs broken. a little yellow, could use a rub over with some toothpaste. $60 driver side front guarder guard, small dint at very top of wheel arch $60 oem amber side indicators $30 oem clutch master & slave, hardline and damper all still connected. $90 R32 bm44 brake master cylinder ( this was the unit i purchased as an upgrade for my 180 but using the 33 master and booster now so selling the 32 master ) $80 r33 turbo manual lsd, shimmed up. locks very nice, not over shimmed. non ABS $150 r33 s1 oem front floor mats $40 r33 rear parcel shelf with 6x9's $50 passenger + driver sun visors $25 rear view mirror $10 r33 carpet, no rips etc $30 fuel tank $60 boot with slight dint in the top $30 passenger side tail light $30 driver side tail light $30 bonnet $60 3" catback, chopped out mid muffler with xforce cannon $80 oem dump + front pipe with oem gutted cat $50 front hubs + knuckles complete. does NOT include LCA's $60 rear monkey brace $60 MDU coilovers, spring height adjustable. no knocks or leaks $300 ALL located in wollongong. will post up more items tomorrow, and pics of items as well. contact by pm or Nik on 0416 129 811. Edited December 27, 2011 by nik. Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/ Share on other sites More sharing options...
frozenwaffles Posted December 27, 2011 Share Posted December 27, 2011 Interested in engine... Talk soon Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6166740 Share on other sites More sharing options...
bull_11 Posted December 27, 2011 Share Posted December 27, 2011 Do u have the blinker relay under the dash with plug? Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6166813 Share on other sites More sharing options...
W0rp3D Posted December 27, 2011 Share Posted December 27, 2011 What color? If black do you have front bar and reo both uncut? Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6166931 Share on other sites More sharing options...
Nevastator Posted December 28, 2011 Share Posted December 28, 2011 Do you have the radiator (stock), air-con condenser, thermo fan (w/shroud)? Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6167089 Share on other sites More sharing options...
crowzzz Posted December 28, 2011 Share Posted December 28, 2011 are these still available driver side window control, fully functional. all buttons work perfectly $40 driver side door skin $30 r33 turbo manual lsd, shimmed up. locks very nice, not over shimmed. non ABS $150 r33 s1 oem front floor mats $40 r33 rear parcel shelf with 6x9's $50 Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6167409 Share on other sites More sharing options...
woods Posted December 28, 2011 Share Posted December 28, 2011 Engine gone?? Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6167710 Share on other sites More sharing options...
nik. Posted December 28, 2011 Author Share Posted December 28, 2011 Do u have the blinker relay under the dash with plug? yes it would be there, not sure which one it is tho? What color? maroon If black do you have front bar and reo both uncut? front bar yes, has abit cut out to fit fmic. reo unfortunately not, previous owner cut most of it away to fit a fmic Do you have the radiator (stock), air-con condenser, thermo fan (w/shroud)? radiator yes, selling for $40, air-con condenser i should, left it at a mates house so ill check he still has it. sold the fan & shroud already are these still available driver side window control, fully functional. all buttons work perfectly $40 driver side door skin $30 r33 turbo manual lsd, shimmed up. locks very nice, not over shimmed. non ABS $150 r33 s1 oem front floor mats $40 r33 rear parcel shelf with 6x9's $50 yes, they are all still available Engine gone?? nope still have the engine Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6167815 Share on other sites More sharing options...
Bsa Posted December 28, 2011 Share Posted December 28, 2011 How much for the box without the enigne Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6167871 Share on other sites More sharing options...
nik. Posted December 29, 2011 Author Share Posted December 29, 2011 How much for the box without the enigne sorry mate, box unavailable as its attached to my 180 Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6168168 Share on other sites More sharing options...
dori34 Posted December 30, 2011 Share Posted December 30, 2011 What's condition of the coilovers? Can I get pics of them please and how was the quality on the street? Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6169793 Share on other sites More sharing options...
Dylaan Posted December 30, 2011 Share Posted December 30, 2011 Pics of catback please? Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6169853 Share on other sites More sharing options...
nik. Posted January 2, 2012 Author Share Posted January 2, 2012 sorry guys net has been capped and im having trouble uploading. will get pics of the coils and the catback asap. Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6172798 Share on other sites More sharing options...
bull_11 Posted January 4, 2012 Share Posted January 4, 2012 its a small yellow box not much bigger then a match box from memory i think the plug has only 3 wires going into it. Its near the transmition tunnel. if your able to turn the car on flick your blinker and you will hear it click. Sorry about the not to clear instructions im overseas for at the moment and trying to remember off the top of my head. It you have it how much would it be for the box, plug and say 5cm of wiring out of the plug? Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6175476 Share on other sites More sharing options...
Rhinorebel Posted January 5, 2012 Share Posted January 5, 2012 Looking for the bracket that connects the sway bar to the swing arm, need the right one but would take both if you have them please. Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6176213 Share on other sites More sharing options...
street_racer Posted January 6, 2012 Share Posted January 6, 2012 Still got cat back?? Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6177101 Share on other sites More sharing options...
nik. Posted January 7, 2012 Author Share Posted January 7, 2012 Looking for the bracket that connects the sway bar to the swing arm, need the right one but would take both if you have them please. sorry mate only looking to sell complete with the sway bar Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6178261 Share on other sites More sharing options...
nik. Posted January 7, 2012 Author Share Posted January 7, 2012 Still got cat back?? yea sure do. sorry to everyone, im having trouble uploading pics, it would make it alot easier if you sms me for them or send me an email and ill send you pics of requested items. Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6178264 Share on other sites More sharing options...
nik. Posted January 7, 2012 Author Share Posted January 7, 2012 its a small yellow box not much bigger then a match box from memory i think the plug has only 3 wires going into it. Its near the transmition tunnel. if your able to turn the car on flick your blinker and you will hear it click. Sorry about the not to clear instructions im overseas for at the moment and trying to remember off the top of my head. It you have it how much would it be for the box, plug and say 5cm of wiring out of the plug? car is unpowered so cant listen for it, but i will have a look and get back to you. Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6178279 Share on other sites More sharing options...
DLOOOK Posted January 9, 2012 Share Posted January 9, 2012 Honest seller, product as described Nick Link to comment https://www.sau.com.au/forums/topic/386642-r33-s1-partout-complete-engine-package-minus-turbo-fmic-tomei-bms-interior-doors-headlight-tail-lights-exhaust-mdu-coilovers-more/#findComment-6180867 Share on other sites More sharing options...
