What you can try is to disconnect the hose with a clamp( or bypass ist with a short tube) .
Its under the manifold on the left side .
so you can check if it has any effect on the cold start
refering to your cold start Problems this might be interesteing to you
https://www.carpassion.com/forum/thema/58441-308-zusatzluftschieber-reparieren-und-einstellen/#comments
Problem :you can`t get by without removing Manifold.
I Put some Brakecleaner into the Hose to remove the Oildebris, most time the slider is stuck or boken-
