For sale a whole heap of parts. all parts are pickup in Sunshine, Melb, postage can be arranged.
r34 - pm for any other interior parts
gtt/gtr xenon headlights $800
factory steering wheel $100
front seats $200
rear seats $100
stock coilovers with HKS springs(very firm). $200
abs unit $100
seat belts $30 each
boot interior carpet $50
hicas motor $30
rear parcel shelf $50
rear quater plastic trims $80
r33 - striping r33 so pm for any other parts.
trust t67 25g 8cm turbo kit, inc gate, manifold, intake pipe, dump pipe, screamer pipe $3000
6point roll cage for sunroof brand new $1200
hks rear coilovers blown $100
boot strut brace $100
front wide guards 25mm $250
topstage rear wide guards $250
pair drift seats carbon fiber back (scratches on back) no rails $300
gtr wing(burgundy) $250
drift lip/wing(white) $150
spitfire for series 2 rb25 $450
veilside rear bar(black) $150
trial rear bar(white) $150
trust twin pillar gauge pods with some dog bite marks $80
greddy plenum copy $250
passenger side s2 headlight perfect condition $250
standard exhaust manifold and turbo $300
standard intake plenum with runners $150
stock exhaust $80
stock dump and front $50
stock sway bars $70
stock injectors $80
stock ecu $100
s1 afm $100
other random crap
s14/s15 apexi coilovers $900
s14 rear wide body $250
r33/r34 exhaust. HKS HI-Power catback Exhaust $450
r33/r34 jasma exhaust no mid muffler $150
rb25 split dump pipe $70
rb25 front pipe with flex $70
trust type c wastegate $450
auto meter monster taco with shift light $120
s15 dash $200
oldschool blitz bov $100
random turbosmart bov $50
q45 throttle body $200
PICS to come when i have time or pm if you want pics of a certain item. have heaps more parts but cant think of them off top of my head. stripping/scraping r33 and turning a 34 to a track car so pm for any stock parts.
pickup is in western suburbs. pm or forum or sms 0451115111
Edited by tets
https://www.sau.com.au/forums/topic/386655-tets-massive-garage-sale-melb/
some pics that i just took, not sure exactly what size rear guards they are but they just fit my rims.
top exhaust is hks one for sale
r34 ash tray that some people requested photos of
rear bar/gtr wing and rear wide body.
Edited by tets
  • 3 weeks later...
Hey mate, your pm isnt working
Do you have the drivers side A pillar plastic interior peice? in good condition? also the black plastic interior piece behind the side rear view mirrors? must be in near perfect condition.
do you know if they are the same as on the gtr?
Cheers,
Anthony
  • 2 months later...
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
