Hey guys, this morning took the car for a drive and about 1 min into driving my car start to sound like a rex and shaking! When I accelerate it seems to struggle and shake more. After pulling over, popped the bonnet the engine isn't shaking anymore than normal but the exhaust is shaking more at the back. Does this mean its misfiring somewhere in one of the cylinders? Btw I just got the injectors clean and tested and also replaced spark plugs. Please help its been killing me that I can't drive my baby!
Also how do you open the stock r32 gtr air intake box to replace the filter?
Cheers
Amon
https://www.sau.com.au/forums/topic/386656-omg-whats-happening-to-my-baby-help/
Only thing I have done is new mongoose alarm but I don't think that will do anything to it. Got the injectors (standard) clean and tested and replaced spark plugs today and no mods at all only an exhaust. After changing the spark plugs still no change. Still feels like the engine is choking.
Not been running rich at all, using the same ones the NGK Laser Platinum that came out of the car. The coils should come today I hope! Got some yellow jacket coils. How do you fix the gap if there is one in the spark plugs?
Cheer guys!
Get a gap tool or a set of feeler gauges. A "gap" is not really a fault, its the process of measuring up the gap between the electrode and the ground point of the spark plug, The top of the plug has that white thing with the exposed metal which sparks between the body of the spark plug. You measure that gap. 1.1mm is the common standard size. What you do is gently tap the spark plug onto something solid, concrete or something, until the gap closes to about .8mm.
This will NOT fix your problem if you are misfiring on idle. If you misfire under boost only then yes it will. On idle, the WRX sound, means one cylinder isn't running and a coil is dead.
Edited by SargeRX8
Cheers guy for the help, I'm hoping it comes today so I can get the car back on the road. I'm not misfiring at boost so I won't worry about the gap for now. Btw does anyone know how open the stock CAI box on r32 gtr to replace the filter? I'm struggling hard to figure it out.
Thx again guys
Sounds like the module unit is shagged.....start the car then pull the connector one by one off the coils....when you find the one that doesn't make a difference to the cars already missfiring idle try swapping the coil with one from another working cylinder.....if its still no good it's the module unit
Cheers mate for that, how do i fix it? So far I have changed all my coils to yellow jacket coils and replaced my air filter and cleaned the AFM's and also replaced all the spark plugs.
After changing all that and turned the car back on, still sounds like a WRX and shakes and adding to that it seems like the engine wants to stall once in a while. What do I do now? :(
There are 3 things I think it could be, one being unlikely.
1) The ignitor module has failed. This unit is what produces the voltage then sends it to the coil to the spark. It could be f**ked for a particular channel only.
2) The loom is damaged. The wires could have broken inside the clip or somewhere in the line to the coils.
3) The ECU is damaged and can't send the signal to the ignitor to create a spark for X cylinder.
All your symptoms are of a cylinder not firing. WRX on idle is a clear indication one of your cylinders is literally switched off. Fuel going in, no spark, no power, rough, etc. The reason the engine shakes is because the crank is balanced to run with 6 cylinders spinning it smoothly. You now have your car running on 5(or less) cylinders, causing the crank to spin unbalanced.
Get another ignitor from someone to test, from a known working car. If nothing, try another loom, or if you are ok with electronics check for continuity. If those bring no luck, try another ECU.
OK so far what I have done above and now plus a different ignitor. Well guess what nothing still FFS giving me a headache. Where can I find a loom or does anyone have a spare laying around.
Cheers for the info SargeRX8
Hasn't had a compression test as i don't know how to and most of the mechanics are closed during holidays. How big is the problem if the bearings have failed and what will needed to be done if that's the case?
Cheers
Outside of probable coilpack loom issue
- Is there a mechanical reason it cant be one of the main bearings failed causing this ?
- has a compression test been done ?
Pray it's the coil pack loom
You've replaced coilpacks. ignitor, plugs and cleaned your AFM. ECU is very unlikely but it is possible.
If it's not the loom ask your local garage to do a compression test. It will give you a very clear indication if you have done a main (big end) bearing.
Your mechanic is most likely able to tell you even without a compression test.
What year model is your 32 GTR and what if any work has been done to your RB26 ?
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
