interested to see what oil choice people are going for with E85/Eflex now a lot more people are using it.
i've been running AMSoil 10w40 (which i also used on my prev GTT on E85)
but for track days i'm thinking of running something a bit thicker, say a 15w50, but my normal yank choices are a bit limiting in the thicker choices...
specially keen to see what people are running at the track with E85/Eflex and what your experiences are
cheers
https://www.sau.com.au/forums/topic/386659-e85eflex-and-oil-choice/
Keen to do the eflex thing but not as yet.
So far as i can tell the genuine synthetics include (apart from Amsoil) Motul and Agip both of which are pretty widely available. I am getting my oil tested (Motul at present) and want to see if Agip will do the same job as its much cheaper ( as you will know also much cheaper than Amsoil).
Agip do a 10W 60 racing oil which I think might be too heavy.
They also do an "Ultra Syn" in 5W-30, 5W-40 (which I may try next) and a 5W-50
When I first ran e85 I stayed on 10/40 weight oil. I found it broke down very quickly as opposed to when I was running 98 octane leaded fuel neccesitating an oil change every 1000 to 1500 kays. I changed to 20/50 weight and got a major imporvement, Oil pressure remained more stable for a longer period of time...win!
Royal purple has been my oil of choice considering they are one of the few that claim their product is compatible with the alcohol base fuels. However after doing some more research I spoke to The tech advisor of Penrite oil. A local company making product that on paper is at least the equal of anything from anywhere else.
The oil he reccomended for my application was Syn 20, a 20/60 weight oil. His reason was simple, these fuels are brutal on oil and dilution is a major problem, hence the reccomendation for a thicker heavier oil to better deal with the issue.
My experience with the 2 different grades of royal purple have me believe he is correct. I am due an oil change shortly and will be giving the syn 20 a try.
p.s. I was a motul user until I switched to e85. The motul distributor advised firmly against using their product as it is not compatible.
p.p.s. the Penrite product is considerably cheaper than the imported oils so I am hoping it works from that regard as well.
motul only recommend not to use 300v with e85
when running ethanol you shouldn't be using 100% synthetic oils as they cannot absorb any moisture, it is best to run a semi-syn
i use motul 6100 15w50, as it is formulated for LPG and has the highest rate of moisture absorption of the range, it's the highest quality semi-syn they make and it's a 15w50
it doesn't break down like has been described above...
motul rep reccomends this one for e85 rb's too fwiw
- also... i used to run turbolight with no problems, but for trackwork on a 300kw 100,000km motor i wanted something a little thicker
I have been using 300V in my E85 fueled GTR for the past 13 months. Trackday's the lot. I just change it more often. The rumours with the 300V and E85 range from "your oil will turn into jelly like its just come out of the fridge" to "It just breaks down quicker". The current oil in there has done a few kms so I will get this lot and get it tested.
A common oil that gets recommended is the Penrite "sin".
I have been running Sougi 6000 for nearly 2 years now on eflex, no issues with breaking down or going milky. I still have 6 bottles left, I have no idea what i will change to when they run out.
Winter is the time to watch as cold starts are an issue with plenty of fuel washing down past the rings. I used 300v with a low temp thermostat and it turned into a milky mess, I dont seem to have any problems now I replaced the stock thermostat. VQ engine/oil temps sit at around 87 degrees which is hot enough to evaporate any ethanol into the catch can. I doubt you will have issues like this on the track as the oil temps will be high.
Your motul rep and mine sing a different tune Hamish. My rep actually warned me off using any of their product with ethanol.
From my limited experience I think any of them will be ok providing you use the right grade.
any ester based oils are no good for e85
its not the moisture that is the issue, a byproduct of burning ethanol breaks down the oil molecular structure. "hydrocracked" synthetics are "more" suitable,
something about the ethanol structure wich is close to the chemiclas used to make/blend the oil, so it starts being "unmade" if that makes sense. straight from our motul rep, liquimoly rep and penrite rep.
would be worth asking holden what they use for there flex fuel commo..
as far as oils go, penrite syn 15 is my oil of choice. 15w50
with respect to the 'what oil does Holden use' comment i was digging through some BITOG (bob is the oil guy) threads bout a year ago i think... as the yanks have had high E% for a while, the oil recommendations for their flex-fuel cars seemed to change over the years and in the end (from the car manuals) they didn't specify any special oil, just the drain intervals.
I know with motorsport applications you need to be more precise, but from the US it seems for their factory flex fuel cars, the manufacturers didn't recommend any brand/type specifically.
Just wonder how much it's just caution on behalf of ppl like Motul etc, you know, just to be on the safe side...
anyways, i'll check up on some of these other oils mentioned. But like others in this thread, i'll stick with the US oils at this stage as like Royal Purple, AMSoil advise their oils are ok with high % ethanol fuels.
As for UOA, who are we using?
Yeah as said above it's not ALL Motul oils, only the good ones
Ester based = no good for E85
And to reaffirm Noels statement on the RP vs Penrite - RP do a thicker grade of oil we just don't care to bring it in. RP has just been getting dearer and dearer every year. Penrite Sin 10 and 20 have tested equally to the Racing RP and 10W40 RP in all independant tests we have seen. I spoke to the distributor in length about it and they assure me its suitable for E85 also as they don't use the Ester base stocks. Their film strength is equal to the RP racing oil and about 50-100 times more than any other Full syn oil on the market including Mobil, Redline, Castrol, Shell.....any of them
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
