Next time you go to buy Oil look at the API Spec, look for one that is API SN!
API SN is amongst other things its designed for use with E85, more and more new cars are now being designed to run on E85. The new Commodore can run on low octane unleaded or even E85, the compute automaticaly changes the map to suit.
So the oil companies now product an oil designed for E85, that is API SN. I think its the first time a API spec has hadto meet the test procedures for E85.
At United Oil (not united Fuel) we have many API SN products, but like all the other oil companies they will be a Hydrocrack (group 3) base synthetics.
I am suprised the oil companies who have responded to the question on E85 fuels have failed to mention API SN spec, its the most critical factor! Or maybe they arn't API Accreditied?
Info in API SN
List of all the API Petrol engine specs
Ash
the only thing is just because a oil doesn't meet SN standards doesn't mean it can't be used with E85, some of the other criteria's which it might not meet are absolutely no concern to me, however it does raise concerns.
penrite 10 tenths racing meets API SN, the motul is SL, it would be interesting to find out exactly why, that might be in my next email to motul.
that would seem to be a yes...
now to find a list of G5-F oils...
looks like GF-5 might be better than API SN in some regards, as there will be API SN and SN Resource Conserving, SN normal doesn't seem to require emulsion retention... interesting...
I think i'm going to try and find a GF-5 oil to try.
royal purple means API SN and G5-F.
Royal Purple's API SN licensed motor oil meets ILSAC GF-5 and Dexos1™1 performance requirements.
i think i'm going to try RP first, as the penrite 10 tenths range hasn't hit supercheapauto stores yet, and they don't carry motul at all, for the price i will pay for the RP with discount, it's not gonna be much more than the penrite or motul from autobarn.
Yes I do.
The best thing to do is to take regular samples to establish a trend. Regular samples showed contamination caused by the E85. Once I Also found high metal contamination, which they sugested it looked like cam wear. I then inspected the cams and one of the lubricating holes was blocked with some silicon. So sampling is a good thing, helps find potential falures
Ash
You should post this in the oil thread, guys seem to think how their car "feels" when they drive it is a better metric than oil analysis when comparing oils.
as does the AMSoil Signature Series - unfortunately nothing in the thicker scale of things...
apparently the additive package between Mobil 1 and AMSoil is quite different, so you'd prob want to see some real world results between those two particular ones.
- AMSoil Signature Series
- Mobil 1 (not all, would have to be the newer ones)
- RP (i think the HPS and XPR are both API-SN now, will need to check)
- Castrol Edge have a API-SN oil, again, might only be a lighter weight 5w30 etc
might start a thread over at bitog, for some more info (more independent at least)
for the GTR owners, we're probably going to want something more 15w50 so i'll see if i can find a heavier API-SN or GF-5 oil - i'm thinking it might only be like 20w50 options, but we'll see...
Some Penrite options, including a 15w50
MORE PENRITE PRODUCTS TO API SN
Further to Technical Bulletin 172, Penrite are pleased to announce that we have upgraded more of our products to the new API SN specification.
HPR RANGE
These products commenced production in early January, 2011. HPR 5 HPR 10 HPR 15
Previously advised products:
SIN Range
SIN 0W-50 SIN 5W-60 SIN 10W-70 SIN 15W-50 SIN 20W-60
ENVIRO PLUS Range
Enviro Plus 0W-40 Enviro Plus 10W-50
EVERYDAY SYNTHETIC Range
Everyday Synthetic 5W-50 Everyday Synthetic 10W-40
ok, more interesting info which further backs up what some of us have found and been saying... whilst API-SN/ILSAC GF-5 is good there are still going to be oils that are E-85 friendly regardless of this rating. Like the older RP's, AMSoils etc..
Looking at the Penzoil options and noticed that their Penzoil Ultra is an API SM, SL and SJ, ILSAC GF-4 BUT it ALREADY exceeds the cleaning and protection requirements of GF-5 - now, i don't know if that means it's a GF-5 certified oil but what it does seem to mean is that even non SN/GF-5 oils can be ok with E85 and that's pretty much what some of us have found. It might explain why Motul recommend ones like 6100 etc that don't have "the certification"...
As for Penzoil though...
Penzoil Ultra (not Euro)
Penzoil Platinum
Penzoil Gold
Penzoil High Mileage
the other thing to keep in mind though is that not all viscosities/weights seem to get the same ratings. So we'll need to check that.
AMSoil XL and OE lines are API-SN/GF-5 as well
THIS looks interesting, not sure of certification, don't really care... it's AMSoil, specifically mentions alcohol fuels, good weight/viscosity and you can buy in 55 gallon drums :D
http://www.amsoil.com/storefront/rd50.aspx
man, the more i looked into this, the more it seems as if the E85 urban-myths strike again... i'm starting to think any decent oil will be cool, and i have a feeling i'll be changing oil a lot less once i start doing UOA's. Like not even after track days if all is ok....
i know i'm spamming this thread, but this post people will like.
Motul 300V is widely regarded on here, and for good reason. It is also widely denounced for E85 use, even by Motul themselves... not sure what they're worried about??
http://www.socalevo.net/index.php?option=com_smf&Itemid=37&topic=64878.40 - check pg2
http://www.socalevo.net/index.php?option=com_smf&Itemid=37&action=dlattach;topic=64878.0;id=17845;image
http://www.socalevo.net/index.php?option=com_smf&Itemid=37&action=dlattach;topic=64878.0;id=17846;image
http://www.socalevo.net/index.php?option=com_smf&Itemid=37&action=dlattach;topic=64878.0;id=19079;image
Motul held up fine, although the first two at 10w40 300v and the 3rd is 5w40 for some reason, not listed as 300V. This guy was running Mobil 1 before - wear readings were better with the Motul over the Mobil. No 'thinning' issues at all from the ester 300v.
This is on full E85 as well, not eflex levels.
Daniel, was that car using the Mobil 1 and 300V a track car only... IE change after every day/race or was it a road car?
I asked this question to the old bloke at Advan one day and he said in their race cars they use 300V, they just drop the oil after a meet. (Race cars are on E85). He waffled on about the 300V 'turning to jelly' but I have yet to see this happen in my own car.
I saw the 300v jelly when I ran the low temp thermostat and did a few short cold start runs to work in winter. I assume the oil didnt get hot enough to evaporate the ethanol/water as that wouldnt happen very quickly at 68 degrees. No problem with the stock 86 degree one.
the Evo running Motul 300v left it in after track days, hard street driving etc because the UOA said it was fine. I think he was doing auto-x events.
Scotty, maybe that's the issue then... for those people with the set of circumstances that can lead to oil degradation, cold, short trips etc... and of course if you're a company you just say no to everyone because you can't say "oh it's fine except for... this this this" you just tell people it's not suitable, which is correct in certain conditions.
@roy
sif!!! :D
It's ok Brisby, the 32 can handle it... it's time to switch.... come on, i know you want to! :D
EDIT: yep, either made from Sugar-cane or wheat by-product, quite sustainable and won't effect food prices. There should be a project in Vic starting soon where we'll be making ethanol from household waste.
If you went with a API SNAP oil then would the suggestion based on the above be to not have to go crazy with the thickness. Changing often seems to be the key but i would change often on petrol as well so should be no real change.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
