Top bearing. Ignore the scratches on that photo. It's where we pused the piston and rod out.
Bottom bearing.
15 months (10,000 kms approx) of running E85 using 300V 15W-50 oil. Engine was alive for 32,000 kms and used the same oil the whole time. 8000 RPM generally was the shift point but it did see 9000 a few times. They don't look half bad considering the oil pump died and the head is as useless as tits on a bull.
Bottom bearing.
and didnt burn a drop of oil its entire life :worship:
I'd say that would have to do with the super tight clearances and the run in :thumbsup:. Spoke to Mik about the run in and it was long hard pulls in 3rd and 4th up to 6500 within 10 kms of being screwed together. He did that every night for a few weeks on Old Pac.
yeah for sure, was obviously bolted together nicely... stupid pumps :domokun:
Bottom bearing.
What happened to the head to make it useless ?
Oil pump smashed. Ex cam welded itself to a few cam caps, belt jumped a few teeth and every ex valve got a little frisky with pistons (bent every valve and scored the chambers) . Intake cam is ratto.
Fark...talk about a catastophic chain of events caused by one shit part ,hope it didnt damage the RRR block .
maybe the 15w50 was the key then. I know Midori built my 26 on 10w40 300V and i would think that is a standard weight/viscocity for a street R, and if there are indeed issues of thinning etc, perhaps the 15w50 covers that off and it's ok to run the 300V.
Be interesting to see what Motul themselves think after sending them this info.
I would still like to have a sample taken and sent away although after it went bang I wasn't really in the mood! I don't think the amount of metal (or should I say bits of oil pump gear) would give a good and accurate analysis. A susmmary saying "Too much oil pump shavings in oil. May need to check engine" wont tell us much pinch.gif
Maybe chemically the Ester base oil's with alcohol fuels dont mix but changed enough it doesn't become an issue. The longest mine ever went without an oil change was 2000 kms. Track days and dyno tuning it always got new oil.
And you said it wasn't using oil! Man, that's "using" oil. ;)
Does that mean an ester based oil is fine to use with an alcohol based fuel? (getting back on topic)
it's actually more time that's important than k's. if you take your car for a thrash, have a bunch of contamination sitting in the oil, it has time to react with the ester even if it's not being driven. obviously the more k's and the more blow by = more contamination, so it's a mixture of a few elements really. but yeh, from what penrite say, they believe that you will generally need to change oil for other reasons before the ester begins to break down, so with regular changes it is ok. i'm gonna aim to change every few months which will be about 4-6 track days, so should be fine.
with how you drive? what kinda oil temps are you seeing at the track?
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
