Hey Paul, if by oil analysis you mean take a test tube to someone for scientific analysis then probably not. I wouldn't know the first thing about that
If you mean visuals of water contamination + photos, of course! :P
Plus, I'm not sure how relevant my analysis would be to you, I only own a lowly gtst, not a full house 2.8 GTR! :P
Ethanol and fuel is same same. It gives no fark for car type or capacity haha.
I made the change to E85 a few months back. I have been using the Penrite sin range for years.
After going to E85 I put some fresh Penrite sin 20/50 in and dropped it today after maybe 3000km.
Oil looked fine. My car is making 270rwkw and has nearly 200k on the clock. It gets looked after but does get a boot full every now and then. To be honest I can't fault the Penrite stuff. I have tried RP and the Motul oils and my car just doesn't seen to like it as much as the Penrite. My 2cents anyway.
i run pentrite with E85 as does everyone i know when they are running E85. Seems to be the oil of choice and doesnt seem to break down as quick as some of the others under these conditions..
if you do some searching on the net you will find that ALOT of people say the same thing so thats a winner IMO
Ok so dropped out the Edge 10w60 over the weekend. Here's my super scientific analysis: It was fine. It looked and smelled like any other oil I've changed before.
I copied the technique I read in Performance Imports magazine by stirring up the oil to see if there was water separated from the oil that would show up as white stuff where you stir it, but I saw nothing.
Note: this is a 270kw r33 gtst that is driven every day, South East QLD weather, lots of extra urban trips when cold < 5 mins driving.
Pics:
20w50 is too thick for dailying an SR20 with just a squirt here and there...
honestly i'd look at something a little thinner, especially on the cold viscosity... penrite have a 10w50 syn dont they?
Edge 10w60 is probably the most one common used in vic
Well it looked pretty good to me? How can you tell if it's broken down?
I would have thought with the type of conditions I operate my car in, it would have gone bad if it was ever going to.
I drive plenty of short trips with a cold engine, where fuel can apparently wash past the rings and into the oil etc and break it down. I do no highway kms, all around town driving. Stop start.
heaps of people use it however I havent ith e85, only 98... personally I prefer motul 6100 15w50 with e85 so I can't really comment personally...
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
    • Hi. Yeah i think that DIS-008 should be ok too but i rather asked. The R8 coils are "sadly" no go for me cuz every solution is for forward plenum. The coils are too tall and one of the(4/5 DK) would not fit under stock J-pipe. And being this NA RB20 i dont even know where to get some forward plenum.(and of course i would need other stuff like custom AFM/ECU etc) and that is kinda non sense for NA without boost. I just looking for solutions for my case 🙂  I try look into those Yaris/Corolla ones.
    • Damn it, no, I topped up before I got to yours I really should look at Costco locations more when I'm out and about burning through fuel
    • Did you hit the one 5 minutes down the road from my place before heading back south? 😛
    • Costco uses Mobile as a supplier, I always get Costco 98 when I'm near one, they are typically about 30 cents or more cheaper than the local Mobile
