Lol as part of your reliability testing?
i have been running nothing but the best magnatech for a while now
purchased at supercheap ( i did run half a tin of the diesel magnagtech throgh it last oil change as they look the same)
special on this weekend, i think ill stock up
20% off fark yea!
Pretty sure the Brad Penn stuff is fine Mick as forced performance recommend that stuff in their JB turbos and all the evos in the states use it :)
I run the Brad Penn oil, which has ZDDP additives in it, anyone know if that is ok with E85 as I will be tuning on that in 3 weeks
What one Evo person found .
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2880944
Just changed the oil in my 33 yesterday and again Rotella T6 and a genuine filter .
My Skyline at 125K doesn't burn any and it doesn't come out smelling of ethanol after 6000k .
My take on lube oil is viscosity additives and price . The viscosity relates to cold and running oil temps and oil pressure soon tells you if the viscosity is inadequate . At over 100000 ks I don't expect to have as new bearing clearances so I don't use 30 weight oils .
The right anti wear additives look after the valve train and turbo running surfaces .
I don't think price is a good indicator of lube oil quality so if you find a good oil that isn't expensive - compared to some ....
Oh and by the way T6 significantly reduces the "lifter" , hydraulic rocker pivot actually , tick in my Evo 6 . It was bad at times using Mobil 1 4T Racing 10W40 which is quite high in ZDDP and better IMO than any of the available car M1 oils .
A .
  • 3 years later...
Been using Penrite 10tenths 15W-50 in my 340,000km RB30 pushing 350+ kw for the last 2 years on E85. Its used for daily/drifting and i don't have an oil cooler and at places like QR it cops 2 full days (probably 12ish hours of actual driving) up to 40+deg outside temp and i have never had any oil problems at all. Change it before every drift day and it never looks too bad (classic E85 smells/discolouration)
I know no scientific evidence but i will not run anything else after how well it has treated me for so long.
  • Like 2
  • 3 months later...
I use penrite hpr 10w-50 full synthetic .
Penrite says its e85 compatible but recommended that the oil be changed more frequently. They dont specify what frequently is but id say every 3000-5000 km is frequent enough or after a track day.
I recently converted to e85 in my r34 gtt, and on the first day the oil already smells like E85.
Car is a daily driver with 360 killerwasps
When i do a oil change ill take a picture.
That new nulon racing oil is f**king pricey when you need 10l of it for an oil change.
I just buy 4 bottles of Penrite racing when supercrap/repco have their big discounts racq etc. Ducted setrab oil cooler means 10w40 is enough for a 4 /5 lap sprint.
Edited by burn4005
  • 1 year later...
Has Castrol Edge (Supercar Engine Oil 10W-60) changed there formula ? or just relabeled it ? is still safe to use on e85 or should i move to
Penrite 10 TENTHS RACING 15W-50 ?
Has any one used ULX110 ?
https://ulx110.com.au/?fbclid=IwAR39q18vX3Y3WEduSMWTwFzYVv_VlMtbH7u0RuXDbUPVyyX874idlqHIpw0
    • @GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad.   @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
    • Hi, I went to the MINES shop here and bought something.. Niikura-San just happened to be there so I managed to take some pics and got him to sign my dash surround thingy. Its still wrapped in plastic back home.. I was thinking how to preserve the signature??? Im sure someones thought of this and done this in the past.
    • Perfect - thanks Joshuaho96!  Will see what I can source.
    • If the plastic wore, the paint will wear quicker. Heck, most car manufacturers cant keep the coatings they put on their buttons/trims alive these days for more than 5 years... A cheap paint won't do it!   However, you can get away with high quality vynil wrap, primarily in areas that won't cop much abuse. Skip colour matching, and just try and wrap a specific area with an edge in a new colour.   PS vynil wrapping is a prick of a job, and I suck at it, even for a small dead flat surface...
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
