Hey Paul, if by oil analysis you mean take a test tube to someone for scientific analysis then probably not. I wouldn't know the first thing about that
If you mean visuals of water contamination + photos, of course! :P
Plus, I'm not sure how relevant my analysis would be to you, I only own a lowly gtst, not a full house 2.8 GTR! :P
Ethanol and fuel is same same. It gives no fark for car type or capacity haha.
I made the change to E85 a few months back. I have been using the Penrite sin range for years.
After going to E85 I put some fresh Penrite sin 20/50 in and dropped it today after maybe 3000km.
Oil looked fine. My car is making 270rwkw and has nearly 200k on the clock. It gets looked after but does get a boot full every now and then. To be honest I can't fault the Penrite stuff. I have tried RP and the Motul oils and my car just doesn't seen to like it as much as the Penrite. My 2cents anyway.
i run pentrite with E85 as does everyone i know when they are running E85. Seems to be the oil of choice and doesnt seem to break down as quick as some of the others under these conditions..
if you do some searching on the net you will find that ALOT of people say the same thing so thats a winner IMO
Ok so dropped out the Edge 10w60 over the weekend. Here's my super scientific analysis: It was fine. It looked and smelled like any other oil I've changed before.
I copied the technique I read in Performance Imports magazine by stirring up the oil to see if there was water separated from the oil that would show up as white stuff where you stir it, but I saw nothing.
Note: this is a 270kw r33 gtst that is driven every day, South East QLD weather, lots of extra urban trips when cold < 5 mins driving.
Pics:
20w50 is too thick for dailying an SR20 with just a squirt here and there...
honestly i'd look at something a little thinner, especially on the cold viscosity... penrite have a 10w50 syn dont they?
Edge 10w60 is probably the most one common used in vic
Well it looked pretty good to me? How can you tell if it's broken down?
I would have thought with the type of conditions I operate my car in, it would have gone bad if it was ever going to.
I drive plenty of short trips with a cold engine, where fuel can apparently wash past the rings and into the oil etc and break it down. I do no highway kms, all around town driving. Stop start.
heaps of people use it however I havent ith e85, only 98... personally I prefer motul 6100 15w50 with e85 so I can't really comment personally...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
