Top bearing. Ignore the scratches on that photo. It's where we pused the piston and rod out.
Bottom bearing.
15 months (10,000 kms approx) of running E85 using 300V 15W-50 oil. Engine was alive for 32,000 kms and used the same oil the whole time. 8000 RPM generally was the shift point but it did see 9000 a few times. They don't look half bad considering the oil pump died and the head is as useless as tits on a bull.
Bottom bearing.
and didnt burn a drop of oil its entire life :worship:
I'd say that would have to do with the super tight clearances and the run in :thumbsup:. Spoke to Mik about the run in and it was long hard pulls in 3rd and 4th up to 6500 within 10 kms of being screwed together. He did that every night for a few weeks on Old Pac.
yeah for sure, was obviously bolted together nicely... stupid pumps :domokun:
Bottom bearing.
What happened to the head to make it useless ?
Oil pump smashed. Ex cam welded itself to a few cam caps, belt jumped a few teeth and every ex valve got a little frisky with pistons (bent every valve and scored the chambers) . Intake cam is ratto.
Fark...talk about a catastophic chain of events caused by one shit part ,hope it didnt damage the RRR block .
maybe the 15w50 was the key then. I know Midori built my 26 on 10w40 300V and i would think that is a standard weight/viscocity for a street R, and if there are indeed issues of thinning etc, perhaps the 15w50 covers that off and it's ok to run the 300V.
Be interesting to see what Motul themselves think after sending them this info.
I would still like to have a sample taken and sent away although after it went bang I wasn't really in the mood! I don't think the amount of metal (or should I say bits of oil pump gear) would give a good and accurate analysis. A susmmary saying "Too much oil pump shavings in oil. May need to check engine" wont tell us much pinch.gif
Maybe chemically the Ester base oil's with alcohol fuels dont mix but changed enough it doesn't become an issue. The longest mine ever went without an oil change was 2000 kms. Track days and dyno tuning it always got new oil.
And you said it wasn't using oil! Man, that's "using" oil. ;)
Does that mean an ester based oil is fine to use with an alcohol based fuel? (getting back on topic)
it's actually more time that's important than k's. if you take your car for a thrash, have a bunch of contamination sitting in the oil, it has time to react with the ester even if it's not being driven. obviously the more k's and the more blow by = more contamination, so it's a mixture of a few elements really. but yeh, from what penrite say, they believe that you will generally need to change oil for other reasons before the ester begins to break down, so with regular changes it is ok. i'm gonna aim to change every few months which will be about 4-6 track days, so should be fine.
with how you drive? what kinda oil temps are you seeing at the track?
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
