I've got a 4.083 diff at the moment, which I think feels too tall especially when it takes so long to wind from 0-3000rpm *yawn*
Do you think I would benefit much from going to the 4.363 LSD item that's available?
Can I near a few opinions on this? Personally I reckon it'll be sweet :)
https://www.sau.com.au/forums/topic/38670-changing-roomser-diffs/
What are you doing revving it under 3000rpm in the first place?
You will rip through the midrange and top end quicker, and have to chance gears more.
Gear changing especially on a mountain run, you'll have to shuffle the box more.
You have to remember that the power delivery of the car has an influence on how long it takes to get from 0-3000rpm, its not a bottom end torque monster. Shortening the gearing has other consequences. It'll rev higher @ 100kmh, will use more fuel most likely, gear changing as mentioned.
I would keep it as is if it's good over 3000rpm.
    • It sounds like the perfect time to do easier tasks like, work out how to pull the headlights fully apart, clean them inside and out, and make them meticulous... Or lose all the clips, f**k up polishing the lenses, and get frustrated with that job while you can't do bigger more fun ones and wind up with no usable headlights...   I mean... What?! 😛
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lipomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, more time to contemplate rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
