hey guys, ive been contemplating this for a while ive just never got around to actully posting up a question.
Anyway, ive been offered a ct26 turbo and a new rebuild kit off a gt4 celica for free from a family member. after a quick search on here i didnt really find anything about an rb25 application (only rb20).
so i was wondering, can this turbo be used effectivly on am rb25 if a long morot was purchased and what power figuers is this turbo capable of? :)
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/
Don't. The CT26 from the 3SG is too small. The one from a 1JZ is better suited, but hardly worth the effort to fit it up. Having to buy a long motor, deal with manifolding and plumbing and piping and all the other horror just to use a free turbo, makes the freeness of the turbo completely irrelevant.
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6167935
ye there is...
2nd hand gcg highflow, fmic and nistune will see you to ~230rwkw in a 25 for 2k
fmic $500
2nd hand gcg hiflow $1000
nistune supply, install & tune $1000
= $2500
dont forget the new gaskets and any studs that may break during installation.
would need at least $3500 minimum for 250rwkw range.
he will need turbo back exhaust, fuel pump, injectors and Z32 afm to maximise the highflow.
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6168001
you will spend more on supporting parts to actually have the CT26 fit. wrong flange patterns and all the rest.
you could simply send your stock turbo to hypergear and have it sent back for $960 with everything you need to bolt it straight back on with minimal fuss.
you will then need the suggested FMIC, TBE and a fuel pump as minimum before you go get it tuned. At minimum you are looking at about $800 for a china spec exhaust that will probably be extremely loud. $500 on a china FMIC kit then the suggested $1000 on a nistune (these are ROCK BOTTOM prices and you will probably pay more) and $200 on a fuel pump
you will need to install these yourself to meet these prices
Then you will be limited to 220rwkw by your stock injectors and stock afm, add another 1000 atleast to purchasing these and you will be able to chase 240kw.
If you want more you can get a different option from hypergear which can cost up to about 1550, and go a lot harder. however you will then need to mod more cooler piping and a new intake pipe, budget another $500 for this.
Your call, weve covered this sort of thing over and over.
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6168052
fmic $500
= $2500
second hand highflow's go for as little as $800 and a second hand fmic kit will be ~200
nistune shuold be less than 1k
however you are correct, he will need an exhaust, as well as a clutch
injectors, afm and fuel pump can be purchased at a later date if he wants
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6170221
<br />isnt that what they use on the TT soarers?! They are pretty small.<br />
<br /><br /><br />
No. Those are CT12s - like a smallish t25 size, almost T2. The Toyos also use CT20s, which are like a T28/T3 at the lower end of the Nissan Hitachi sizing and the CT26 which is like the upper end of the Nissan Hitachis. Sort of.
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6171068
righto fail project, just gona hold the na then sell it and buy a turbo, was just a side idea to build the engine so it wasnt just one lump sum piece by peice.
its all good (plus this can be used as a reference if anyone else gets this bright idea lol)
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6172055
I had a Gt4 celica and had the CT26 highflowed by precision turbos apparently it had a TO4Z compressor wheel fitted and 360 degree thrust bearing and was told it would flow 400hp :thumbsup:
But dont use it on an RB as all the boys said sell up buy a turbo car that somebody else has pumped all their coin into for sweet F A :cheers:
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6172095
Toyota Surf turbo, eww.
Sorry for off topic but
Toyota surf is actually a ct20b. The ct26 was fitted to 3sgte and 7mgte. So the ct26 isn't a bad option if it's the one from a supra/soarer. Might be slightly laggier then stock but yer.
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6172885
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
