hey guys, ive been contemplating this for a while ive just never got around to actully posting up a question.
Anyway, ive been offered a ct26 turbo and a new rebuild kit off a gt4 celica for free from a family member. after a quick search on here i didnt really find anything about an rb25 application (only rb20).
so i was wondering, can this turbo be used effectivly on am rb25 if a long morot was purchased and what power figuers is this turbo capable of? :)
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/
Don't. The CT26 from the 3SG is too small. The one from a 1JZ is better suited, but hardly worth the effort to fit it up. Having to buy a long motor, deal with manifolding and plumbing and piping and all the other horror just to use a free turbo, makes the freeness of the turbo completely irrelevant.
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6167935
ye there is...
2nd hand gcg highflow, fmic and nistune will see you to ~230rwkw in a 25 for 2k
fmic $500
2nd hand gcg hiflow $1000
nistune supply, install & tune $1000
= $2500
dont forget the new gaskets and any studs that may break during installation.
would need at least $3500 minimum for 250rwkw range.
he will need turbo back exhaust, fuel pump, injectors and Z32 afm to maximise the highflow.
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6168001
you will spend more on supporting parts to actually have the CT26 fit. wrong flange patterns and all the rest.
you could simply send your stock turbo to hypergear and have it sent back for $960 with everything you need to bolt it straight back on with minimal fuss.
you will then need the suggested FMIC, TBE and a fuel pump as minimum before you go get it tuned. At minimum you are looking at about $800 for a china spec exhaust that will probably be extremely loud. $500 on a china FMIC kit then the suggested $1000 on a nistune (these are ROCK BOTTOM prices and you will probably pay more) and $200 on a fuel pump
you will need to install these yourself to meet these prices
Then you will be limited to 220rwkw by your stock injectors and stock afm, add another 1000 atleast to purchasing these and you will be able to chase 240kw.
If you want more you can get a different option from hypergear which can cost up to about 1550, and go a lot harder. however you will then need to mod more cooler piping and a new intake pipe, budget another $500 for this.
Your call, weve covered this sort of thing over and over.
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6168052
fmic $500
= $2500
second hand highflow's go for as little as $800 and a second hand fmic kit will be ~200
nistune shuold be less than 1k
however you are correct, he will need an exhaust, as well as a clutch
injectors, afm and fuel pump can be purchased at a later date if he wants
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6170221
<br />isnt that what they use on the TT soarers?! They are pretty small.<br />
<br /><br /><br />
No. Those are CT12s - like a smallish t25 size, almost T2. The Toyos also use CT20s, which are like a T28/T3 at the lower end of the Nissan Hitachi sizing and the CT26 which is like the upper end of the Nissan Hitachis. Sort of.
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6171068
righto fail project, just gona hold the na then sell it and buy a turbo, was just a side idea to build the engine so it wasnt just one lump sum piece by peice.
its all good (plus this can be used as a reference if anyone else gets this bright idea lol)
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6172055
I had a Gt4 celica and had the CT26 highflowed by precision turbos apparently it had a TO4Z compressor wheel fitted and 360 degree thrust bearing and was told it would flow 400hp :thumbsup:
But dont use it on an RB as all the boys said sell up buy a turbo car that somebody else has pumped all their coin into for sweet F A :cheers:
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6172095
Toyota Surf turbo, eww.
Sorry for off topic but
Toyota surf is actually a ct20b. The ct26 was fitted to 3sgte and 7mgte. So the ct26 isn't a bad option if it's the one from a supra/soarer. Might be slightly laggier then stock but yer.
https://www.sau.com.au/forums/topic/386719-ct26-on-rb25/#findComment-6172885
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
    • I much prefer colder weather to hot weather, and especially prefer cold to hot and humid, Goulburn does gets pretty warm in the hotter months, but, I've found the humidity there is not as painful as even Sydney, the humidity up north is to oppressing for this old rooster  In saying this, it does get rather "nippy" in Goulburn for early morning, late in the evening walks, but nothing that a layer or two, some thermal gloves, and a beanie doesn't fix to make it an enjoyable experience, which is much more bearable to me than the oppression of heat and humidity,  especially at night when your trying to sleep If I recall correctly, a "wise man" once said that the "Southern Tablelands" was gods country, and I will not argue that point with him for the fear of a "permaban" LOL In car part related news: My intake is currently in Botany getting processed for the last leg of its shipping journey to my door
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
