Hi guys,
I came accross someone selling this the other day, and i've never seen it before on a R32 skyline, GTR, GTS-T or GTS4. It looks like an extra piece that sits in the centre console box, with possibly 2 switches and a money compartment. It can't be seen on the FAST program diagram for the centre console box for R32 models.
Any Nissan Guru's out there have any idea what this, or where to get it? or was it optioned on any of the R32 models.
Thanks
https://www.sau.com.au/forums/topic/386726-r32-skyline-console-box-variation/
Could be wrong but that looks alot like an R33 GT-R Centre console. The little coin tray bit is the giveaway in my opinion. Would be cool if it was for a 32 though because it would be a pretty rare item. Pity its sitting in the rain in that pic haha
Yea I still have no clue what it is. I just saw it for sale somewhere and thought someone might know, Its def a R32/R33 console. Just be cool to know if its custom, or some type of cool factory option haha.
Yeah it's for a cd stacker or something. I got one in my 32. I removed all the wiring when i put in my headunit. Top left switch for mine was a turbo timer, but it was fried so I hooked the switch up to the tv and now its a on/off switch to use with the handbrake. That hole is ment to be a LCD display. But I haven't seen that nismo thing before.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
