Hey everyone im pretty new to SAU forum and would just like to say hey for starters :D
Just got my first skyline !! WOOT
I have had it for about 3 months now , i have been into them for agez and is a dream come true to finally own one xD
I however unfortunately yet am not the go to guru about the car and still learning about it ' mechanically' which has been fun.
I have come here to ask the question and hopefully get some good responses towards my skyline and any constructive comments are
more the appreciated =D
I have had a few friends and a few random skyline owners i have come across in my travels have a look at my car and i haven't really got a set
answer as to; What series my skyline actually is ?
Helping me out with this will help me better understand my car and i wont be going to buy S2 parts instead of needing S1, visa versa teehee.gif
Also any cool upgrades you think would go nice with this car please let us know
Cheers Guys!
Ps: One of the lights says S2, but i think it may because of a replaced headlight..
Edited by 2ToneSkyline
I see thankyou, well apparently mine is 1995
What fits on 1.5 ? mainly S1 things or does 1.5 have its own type of bodys etc?
Im looking at buying someones S1 front body this weekend would like to know if its gonna fit :)
S2 front end, S2 engine, S1.5/S2 steering wheel, S1 interior, S1 wing, S1 rear gander. Bit of a tough one, but being a 1995 model it's definately a S1.5.
^WHS
But S2 comes with a different S/wheel.
Edited by 10 4
Definitely Series 1.5 with S2 front conversion and for some retarded f**ked reason a S1 wing lol
Fronts bars are all interchangeable, just not grills and bonnets due to the difference in headlights.
LOL, didnt look at plates, sorry.
You guys should have a "PAY IT FORWARD" section over there like we do in the SAUNSW members section, we use it for parts that are gathering dust in the bowls of our garages and sheds, you put all your spares up for free but you get to pick other parts which you get for free, old school swap meet style.
Someone give this man a S2 wing.
Front bar is NOT exactly interchange, the lower edge of the series 2 headlights sits back further than the series 1 lights so the top edge of the bumper is also different. With that said they will swap over and look ok from a distance but it won't be right. Just stick with the series 2 front.
Also for other folks looking to identify an R33 its actually quite simple, just check the chassis number:
ECR33-0xxxxx = series 1
ECR33-05xxxx = series 1.5
ECR33-1xxxxx = series 2
The same basic rules applies for many Nissan models.
Edited by kakimoto33
oh awesome :D thankyou i shall check that soon
yeah unfortunatly my front bar is cracked to far when i bought it i can see the cops just hounding me, i just got a s1 front bar for a sweet deal :)
ill let you guys know how it goes and post a pic of it
cheers
Cheers Guys!
depending on whats been done already, some really basic upgrades that i have done to my 33 are very simple ones, installed a boost tee and boost gauge, uped the boost to 9PSI (will be going to 10-12 in probably the next day or so), plus a CAI system, i did these upgrades only as the previous owner had already installed a 3"exhaust from turbo back and a FMIC (had a monsta brand, swapped it out with a saber one i had lying around) and from my understanding, these little upgrades can produce from my understanding about 20 RWKW (correct me if i'm wrong)
Should save up for an electronic boost controller. Boost Ts will eventually f**k out but before that happens they have the potential to boost spike and overboost your engine AFAIK.
    • This is the GTR fuel pump. Yellow shows 12V, orange shows earth. The ECU provides the earth to activate the fuel pump relay. The ECU side of teh relay will pull low when the ECU activates. This is the RB20 fuel pump. Almost the same, but a little simpler. You can see I indicated (above) where the 12V line goes down to the RB20 diagram on the overall diagram, whch shows both RB26 and RB20. This is where I show it coming in on the RB20 diagram below. You can see that the dropping resistor is handled differently. When the fuel pump control is not providing earth to the pump, the pump earths through the dropping resistor and thus runs at lower voltage (some is wasted over the resistor) and runs slower. I showed that "not 12V and not quite earth" portion of the wiring in a paler orange. The rest of the wiring that I did not colour on that little section below the pump would be orange when the fuel pump coontroller is providing earth. This drop is handled inside the fuel pump controller in the GTR. Regardless, you can see where 12V is supposed to be, where earth is supposed to be. The key on prime is via the ECU providing the pump for only a few seconds the switching off. You should be able to see that happen.
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
    • They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
