Hey everyone im pretty new to SAU forum and would just like to say hey for starters :D
Just got my first skyline !! WOOT
I have had it for about 3 months now , i have been into them for agez and is a dream come true to finally own one xD
I however unfortunately yet am not the go to guru about the car and still learning about it ' mechanically' which has been fun.
I have come here to ask the question and hopefully get some good responses towards my skyline and any constructive comments are
more the appreciated =D
I have had a few friends and a few random skyline owners i have come across in my travels have a look at my car and i haven't really got a set
answer as to; What series my skyline actually is ?
Helping me out with this will help me better understand my car and i wont be going to buy S2 parts instead of needing S1, visa versa teehee.gif
Also any cool upgrades you think would go nice with this car please let us know
Cheers Guys!
Ps: One of the lights says S2, but i think it may because of a replaced headlight..
Edited by 2ToneSkyline
I see thankyou, well apparently mine is 1995
What fits on 1.5 ? mainly S1 things or does 1.5 have its own type of bodys etc?
Im looking at buying someones S1 front body this weekend would like to know if its gonna fit :)
S2 front end, S2 engine, S1.5/S2 steering wheel, S1 interior, S1 wing, S1 rear gander. Bit of a tough one, but being a 1995 model it's definately a S1.5.
^WHS
But S2 comes with a different S/wheel.
Edited by 10 4
Definitely Series 1.5 with S2 front conversion and for some retarded f**ked reason a S1 wing lol
Fronts bars are all interchangeable, just not grills and bonnets due to the difference in headlights.
LOL, didnt look at plates, sorry.
You guys should have a "PAY IT FORWARD" section over there like we do in the SAUNSW members section, we use it for parts that are gathering dust in the bowls of our garages and sheds, you put all your spares up for free but you get to pick other parts which you get for free, old school swap meet style.
Someone give this man a S2 wing.
Front bar is NOT exactly interchange, the lower edge of the series 2 headlights sits back further than the series 1 lights so the top edge of the bumper is also different. With that said they will swap over and look ok from a distance but it won't be right. Just stick with the series 2 front.
Also for other folks looking to identify an R33 its actually quite simple, just check the chassis number:
ECR33-0xxxxx = series 1
ECR33-05xxxx = series 1.5
ECR33-1xxxxx = series 2
The same basic rules applies for many Nissan models.
Edited by kakimoto33
oh awesome :D thankyou i shall check that soon
yeah unfortunatly my front bar is cracked to far when i bought it i can see the cops just hounding me, i just got a s1 front bar for a sweet deal :)
ill let you guys know how it goes and post a pic of it
cheers
Cheers Guys!
depending on whats been done already, some really basic upgrades that i have done to my 33 are very simple ones, installed a boost tee and boost gauge, uped the boost to 9PSI (will be going to 10-12 in probably the next day or so), plus a CAI system, i did these upgrades only as the previous owner had already installed a 3"exhaust from turbo back and a FMIC (had a monsta brand, swapped it out with a saber one i had lying around) and from my understanding, these little upgrades can produce from my understanding about 20 RWKW (correct me if i'm wrong)
Should save up for an electronic boost controller. Boost Ts will eventually f**k out but before that happens they have the potential to boost spike and overboost your engine AFAIK.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
