Can anyone please tell me were i can get rear cradle bushes and rear diff mount rubber for my r31 2 door jap import????
Everywhere i try they tell me they are not available or need to be ordered from japan and will take weeks.
This is the only thing stopping my car from being engineered and im desperate can anyone please help?
https://www.sau.com.au/forums/topic/38677-r31-rubbersbushes/
I'm 100% with you. I need a rear diff mount for my coupe too.
They are sooo hard to find short of getting one made custom here in Aust.
does anyone have one they could even loan? Or does something out of another car fit?
I will get a mould made up etc if i can get a loan one :)
https://www.sau.com.au/forums/topic/38677-r31-rubbersbushes/#findComment-783217
Hi Maxx.Not sure if these would be suitable for an HR31,as they don't have a rear steering rack,but little rams that move the whole cradle to effect the rear steering,so these metal bushes may kill the HICAS by making the cradle too stiff.
I'll stand corrected if I'm wrong though. :cheers:
https://www.sau.com.au/forums/topic/38677-r31-rubbersbushes/#findComment-787832
the HR31 setup is a lot differet to that of the R33... not too far from the R32, but still... it was the early days in terms of HICAS.
Also czy18e
Can they gaurantee it fits 100% ?
Where are they located??? As my car is in a suspension place right now and getting one soon would be good.
I'm willing to pay $350 when all i hear is a grenade going off at the rear of my car evertime i hit the clutch!
https://www.sau.com.au/forums/topic/38677-r31-rubbersbushes/#findComment-789003
Got all of them.
Rear Sub Frame and the Diff.
Sub frame is $110 each
and the diff one is $275
I think they come from Nissan Japan... But trying to get them isnt easy as the place i was at had to make a few calls etc.
https://www.sau.com.au/forums/topic/38677-r31-rubbersbushes/#findComment-795887
Centreline Suspension here in Melb got them ordered.
When i go back there next week when they get here i'll ask him who he got them through.
I'm 90% sure he went through Nispares here in Bayswater.
He also said that they look similar to R33 rear bushes.
So we'll confirm that once mine get here as he has some R33 ones sitting around and said they looked almost identical
https://www.sau.com.au/forums/topic/38677-r31-rubbersbushes/#findComment-802416
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
