hi guys ive just got a quick question
i have an NA r34 coupe ive read a couple of threads saying that GT-X has turbo breaks and 17" wheels but im not sure if they came in coupe?
my coupe had the 17" wheels untill u put lenso d1's on and it also has turbo brakes but doesnt have the GT-V interior so its not a GT-V
its not 4 wheel drive either so not a GT-4
didnt come with factory 15" wheels and shitty na brakes so not a GT?
can some one help?
Cheers.
https://www.sau.com.au/forums/topic/386770-confused/
Interior is not 100% the same, for instance the material on the seats are different fabric, the odometer/ (Speed, fuel and oil pressure gauges) are white and have orange lighting.. The font bumper should tell you whether its a GTV not a GTX because a GTX i think is the 2.0 liter R34. The 25GT is the 2.5 liter R34 without the Turbo goods. I know this because i own a 25GT and my friend has a GTV and i have been around that car for a few years now.
https://www.sau.com.au/forums/topic/386770-confused/#findComment-6168713
Rather incorrect.
- You are refering to the differences between the R34 Series 1 and Series 2.
- GTX is a trim level spec on the GT25 and GTt, ie. premium sound, rear privacy glass etc.
- GTv is mechanical spec difference, it is a GT25 + upgraded brakes, LSD and HICAS (all from the GTt)
- 2.0L is plainly known as a GT.
- 2.5L is known as a GT25, GTX, GT4 (AWD model), GTv (GT25 + mechanical upgrades)
- 2.5L turbo is known as GTt and GTt-X
https://www.sau.com.au/forums/topic/386770-confused/#findComment-6169730
Rather incorrect.
Isn't GT-t a 2.0L turbo?
25GT-t is the 2.5L turbo
https://www.sau.com.au/forums/topic/386770-confused/#findComment-6182399
GTS25T is an R33 turbo 2.5L. R33 and R34 model variants didn't come in an RB20DET configuration, only RB20E and RB20DE respectively, both of which were marketed as basically a big Kei car.
https://www.sau.com.au/forums/topic/386770-confused/#findComment-6182689
  • 3 weeks later...
got me confused...?? iv just bought my first r34.. the badge on the back says its a 25gt. dose this mean it dose not have the mechanical upgrades like the 25gtv dose..?
if so dose my 25gt have lsd.. I know one way to find out but i just got it lol :D
CheerZ
MAT
https://www.sau.com.au/forums/topic/386770-confused/#findComment-6250193
  • 3 weeks later...
could be mistaken Mat but i think all the 34 non turbo's came with 25gt on the back, so if yours is a normal 25gt then no it doesnt have the upgrades of a gtv, and no it doesn't have an lsd, one way to confirm althought not 100% accurate if some1 has changed them for whatever reason is to check if you have 4 piston fronts and 2 piston rears (found on gt-v's).
and for the badges on the guards (red/blue), those can easily be swapped.
as for the gt-4, once again im not sure but i think they only came in 4-door? can some1 confirm???
https://www.sau.com.au/forums/topic/386770-confused/#findComment-6273239
