so we're pretty much the same then. Built 26, 2530's. ID1000's and intank Nismo. That's it :)
Full time Eflex use (unless i need to fill up with 98 if i'm not near an Eflex outlet, then i just let the flex-fuel setup take care of things) but 95% eflex use, couple track days and about 6 months i think on this setup
Its about 5 litres in capacity, Nismo "lift" pump (as that what was my intank before the surge tank was installed) and 2 X 044's to feed the engine. I have a Fuel pressure Gauge sitting on my steering column and at no point have I seen pressure drop either on the track or on the street.
I took the car to Unigroup and said "I want a 5 litre surge tank with 2 x 044's, go" and that's what I got.
It may look like it hangs low in the photo's but it definately doesn't.
Piggaz that looks good, can you see the tank from behind the car?
Only when he is going over a crest and you're following at night your headlights will shine off the very bottom edge quickly - so it's very well hidden
Yeah, as Steve said above. Ill take a photo tomorrow and upload it. I'll stand 15 M away to give you an idea. If I just got off my arse and sprayed it back you would be hard pressed to see it.
we all know u will never do it as it would fall immediately into the 'too hard basket'
Nice Setup.
Which brings me to a question - what is the general thought on mounting the pump or pumps in-surge-tank. ie in the surge tank immersed in the fuel?
I have a 044 in tank (main tank) and it runs almost silently, I assume it stays relatively cool and free from corrosion being in fuel. Certainly when you take the 15 yr old stock pump out it looks brand new, as does all the wiring/fittings etc.
Any reason people don't do this other that it being (maybe) more complex?
And also, rather than running duel 044's, is no one running big single pumps like Fuelab, Weldon etc?
I'm looking to do E85 setup soon and so looking at all these options.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
