Nice Setup.
Which brings me to a question - what is the general thought on mounting the pump or pumps in-surge-tank. ie in the surge tank immersed in the fuel?
I have a 044 in tank (main tank) and it runs almost silently, I assume it stays relatively cool and free from corrosion being in fuel. Certainly when you take the 15 yr old stock pump out it looks brand new, as does all the wiring/fittings etc.
Any reason people don't do this other that it being (maybe) more complex?
And also, rather than running duel 044's, is no one running big single pumps like Fuelab, Weldon etc?
I'm looking to do E85 setup soon and so looking at all these options.
If you look at the pump, you would see that the inlet is normally in the middle of the pump, that means you need to keep that much fuel over the pump, in a large area, meaning fuel can slosh/move around, and you can end up with surge.
The larger your surge tank becomes, the less of a true surge tank that it is...
The idea of a surge tank is to keep enough fuel at the pump, while you're cornering/launching and fuel in the main tank can't be picked up... If your surge tank gets bigger and bigger, then suddenly it can come prone to surge...
Also, most people don't require a surge tank, as they don't run fuel low enough in the tank. If it's just a weekender/occasional track day car, just keep the main tank over 1/2 full.
If you're going for ten tenths, then put a surge tank in, and run only 15 litres in the main tank...
^ that's why internal pumps are mounted vertically.
A lot of these under car surge tanks have pretty ugly aspect ratios, if you can't fit something relatively tall compared to it's width what's the point? You'd want to be doing the numbers on max time at WOT, engine fuel demand and lift pump flow pretty carefully to ensure it stays full.
Alot of it falls onto the tanks desgin.
The ones I've been making for years upon years now have a fairly short height. They do however have a lower chamber that's designed for the pumps to feed from and internally baffled with a float type trap door.
I don't recommend running more than 2 044's from them though.
I've got a GTR using a Weldon pump that actually fills it's own surge tank via a -12 hose into the main tank.
The pump draws from the surge using -12. The surge draws from the main tank via -12 and has a trick pick up system that covers most of the tank floor.
With the return also feeding the surge there is always fuel overflowing back to the main tank.
The way we test how well a surge tank is working before selling them is to fit a clear hose between the surge tank and the main tanks return port for a track day or dyno session
Put a camera on the hose and film it for a few sessions.
Obviously if the tank is working properly it should always be returning fuel to the main tank through your clear hose.
If the tank is not working properly or is poorly designed the fuel in the return line will either become airated or non existent if the main pumps are too demanding.
Obviously there are variables like fuel consumption so they need to be tested and rated accordingly.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
