Hi!
My name is Rob. As I type, I'm sitting in the front seat of my (new) 2003 350GT. This is my 3rd Skyline, but my first with such fantastic features and the first with such an extensive computer setup. My first Skyline was a 1990, Series 3, 5-speed Silhouette. Brilliant car. After this, I owned a simple 1990 GXE that I performed a few minor mods on.
I have to say, this 350GT of mine is absolutely something else.
I have been lurking for a few days here and have already found so much useful information on mods, parts and the like for any future tuning or installations. Which judging by the information here and the professionals that seem to post, I'll have quite a V35 on my hands. I have already sent an email off to Xanavi Australia concerning the Japanese to English translation of my nav/computer system thanks to the MANY threads involving the issue.
Hope to make some friends in here and I'll try and keep posting.
Thanks for having me!
https://www.sau.com.au/forums/topic/386861-n00b/
G'day Rob.
Sounds like we are in the same boat gtting a good V35 deal.
I have had the same thing go on with english translation. Unfortunately the 70th anniversay has the carozerria (altough not all of them) and it cant be translated at all.
So best of luck with yours mate.
https://www.sau.com.au/forums/topic/386861-n00b/#findComment-6172701
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
