Also.... March 18th Superlap Australia FB post
In 2010 the Cyber Evo was actually retired from racing..... yet it came to WTAC and took home the trophy........ In 2011 the Cyber Evo was "now officially retired" yet... guess what.... It came back to WTAC and took the victory again..... In 2012.....lets just say, we will "NEVER SAY NEVER"
  • Replies 742
  On 28/03/2012 at 3:50 AM, HKS26T said:
Whispering Jack hard!!!
Cyber GTR was suppose to get a full pamper treatment with its engine management. Unfortunately tilton has held them up with a gearbox. So no goer
My car is supposed to get tuned next month but my tuner is not available between 13th to 23rd ..... why? because ill be
in Japan replacing the Power FC and putting a full system in the Cyber EVO instead........ okkkkaaayyy .... coming to WTAC 2012 wooooot woooooot!!!!
:cheers:
Interesting indeed given the GTR wasn't meant to be ready until 2013 :thumbsup:
This will be interesting indeed to see if they come back "again" lol.
Yes this is correct! but given the fact that Haltech had already planned this trip, it would of been a real waste to cancel
everything.... hence the "COMEBACK" lol
obivously Superlap Australia have done a superb job in presenting a enticing package to make this happen :P
kind of spoils all the fun though that we know now, although it will allow other people to now bench mark improvements in performance against them at an event that will be certain to be very entertaining.
How long you reckon it will take to sell out places this year in open? 3hours last year so maybe 30min this year?
You would have to think there will be a Que at High Octane @ 6am in the morning like a line up for a Justin Beber concert.
I have heard it’s ready full. Entry forms have been sent out to people they would like compete not just the top ten from last year..... hope it’s not true.
That is the point of Pro class.
Superlap have also sent out forms to the top x drivers from last year, all of that information is public and fair I think. If you placed well last year you should have the opportunity to re-enter easily.
yes it appears teh cyber Evo rumours are becoming stronger for a return in 2012
Eric Hsu usually knows whats going on.
http://www.motoiq.com/magazine_articles/id/2452/underneath-the-skin-of-the-legendary-cyberevo.aspx
http://www.motoiq.co...y-cyberevo.aspx
I was just looking at this a couple of hours ago, a great read and especially as they mention the return of Cyber and some guy named Taniguchi :) driving the Top Fuel S2000 with a rumours of 750hp and big aero. Very interesting!
Yeah agreed.
Or you get in contact with Ian & express your interest, details about the car etc and get entry that way.
I'd think that'd be possible for those that haven't come out before, but would draw a big crowd type thing
  On 29/03/2012 at 6:46 AM, R31Nismoid said:
Yeah agreed.
  Quote
promoter reserves the right to reject their entry
Makes perfect sense, you want the field to be nice a close in times and battling it out. Or at least looking good and maybe catching on fire for good measure...(2011 some so 'n so with a R35, lol)
    • https://www.efisolutions.com.au/coolant-temperature-sensor-bosch-180sx-s14-s15-r33?gad_source=1&gclid=CjwKCAjwzMi_BhACEiwAX4YZUHsCQhbiDT_NC3q5wD9jrzH6Dts9eGSr19NXSDw7x9WVm1sH7G3S4hoCwaUQAvD_BwE this is the one i replaced today
    • I have replaced the larger coolant temp sensor, i do see a smaller one next to it (looks to be just 1 pin) but i assume that is just for the dash? or should i replace that aswell?
    • Check coolant temp sensor ~ symptoms fit the hard hot start/cold start OK scenario --- if sensor goes open circuit, ECU thinks engine is cold and enriches mixture ....works when engine cold, but floods them with rich mixture when hot (Hyundi MAP engines are a bit infamous for this)...
    • OK, starter changed for a spare without much trouble. Neil had kindly left space to get to the top starter motor bolt from above with a long spanner which makes the whole deal much easier, and everything else was neat and easy to get at from underneath. Once the starter was changed everything was good, unplugged the CAS and turned the motor on the starter to make sure everything was free and happy. Onto properly priming the oil and first start. I'd picked up one of these oil prime kit from Boost doc a while back and this was my first time using it.  https://boostdoc.com.au/products/engine-oil-prime-kit?_pos=1&_sid=28c628a65&_ss=r While I'd organised all the fittings to hook it up to my GTR (sump plug to -6 feed and -4 T to tap it in and retain the oil pressure gauge, neither suited on this car as the oil pressure needs to T into 1/8 NPT not -4 and the Aeropro sump has some massive drainplug not that factory whatever it is. So, waiting for a couple of fittings, then I'll prime it and do first start, hopefully next weekend. Other than that going well, there is very little stopping a final alignment, tune then shakedown day
    • Also to mention, i just tested the CAS, seems to be working fine, can hear the pulses inbetween 0 and 180 degrees, another mention aswell, when i let the car sit for about a hour today, i went to start it and it almost fired on first crank, then just completely struggled. Could it possibly be blocked injectors?, maybe allowing a little bit of fuel to seep past allowing it it almost start first crank?
