i actually like all of the development of the different cars, pushs all the boundrys around what can be done and not as restrictive. I guess open and club class are for the people that want to push the boundrys within a more defined set of rules.
One thing this year and i hope Hi Octane is reading is to please please put split times up on the display board up, sooooo many times i was hearing.....AND HE IS ON A FLYING LAP!!!! only to see them driving past the start finish line in third with a cup of tea.
  • Replies 742
and as most people know, our R35 won't be there this year. no catastrophes or other major issues with the build other than we have been ambitious with the work planned time wise relative to keeping things on budget. we hope to be on track in several months and spend the year testing at the track and having some fun.
That's a great idea. Have you asked them to do it? Put in on their FB page. Probably gets the most attention haha.
we are going to bring a tv this year so we can plug into the laptimes and maybe a speaker so we can hear the anno
was difficult last.year especially with the rotor guys next door replacing and engine after each session....uncements
Here is a little vid of some testing at Phillip Island on the weekend
Hope you enjoy.
If you like what you see make sure you join the Big Red Racing Facebook Page
Sick love this, do you have a new paint job?
pulse racing evo looks interesting and with a bit of testing, any insight into times @ EC?
In 2010 with far less aero won open class with a 1.46 lap time at EC
Now has heaps more aero, tyre and power looks good reliability wise with new dry sump and motec ECU
Prob Berry will prob be fastest with the 34 in pro class. Was much faster last year compared to before. Haven't heard much since though... Wooster?? Updates??
In open I would say Newton in Big Red for Open class if he pulls it all together. Looks very promising.
Way too many Emo's at WTAC IMO.
should be real quick then, turning into a bit of an EVO fest @ WTA. Who is in the running for fastest Skyline?
Team USA with the 32 will be interesting. Will the Berry machine go faster than Suzuki san though?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
