anyone want to throw a 10 bux in a hat and have a crack at how many engines blow up at super lap?
i say 18
winner takes all or we spend all proceeds on piss and get on it?
It's certainly looking that way with at least 4 engines down in the past 4 weeks across carying classes. Probably more than that given limited info
  • Replies 742
I think a low 28 or high 27 will win it. I've already hear a rumour that the Tilton car has gone faster than Cyber Evo's 2011 time. Could just be rumour but It wouldn't surprise me.
I think some cars in open should really be pro, and we'll see a 33 in open, a few 34s and 35s and the rest spread out in the high 30s and low 40s.
I 39 in Clubsprint is possible too.
There was an EVO doing 1:40 on Saturday at the Creek at a CAMS Supersprint round that will be clubsprint class for time attack and had correct tyres on.
Hence why I predict a 39 is possible. may not happen, but cars are knocking on the door uf sub-40s, which is very impressive on a stree tryre!
I do believe a 39 is there in clubsprint if the track is good and temperatures are right, it is amazing what time attack has done in the last few years to development in supersprint based cars that included open cars. I really need to get my S15 finished but keep devolving new parts to keep up with the competition.
As I said I'll be impressed if it happens. Effectively the only aero allowed under club rules is a big wing so it means most of this time has to come from a combo of good grunt and exceptional pedal skills rather than from some computer generated design that maximizes potential grip.
Anyone have a picture of this EVO?
Yeah I saw the clip of that evo, I recon the driver was sitting a fair bit higher when he got back to the pits. I don't think scrutineers are expected to be structural engineers, only the check basic safety (seates bolted in, fire supression...etc)
Exactly, but you know come a big accident it is going to blow back that way. You hear it all the time "the scrutineers let it run".
There are plenty of good fabricators, and cage builders out there but you wonder what would happen to some of the cars if they went in at turn 1 Skaife-Winfield Commodore style etc. You prey another Todd Wilkes isnt on the cards as some of the cars have nothing structural forward of front suspension pick ups and you have to wonder how they would go in a big off doing sub 1;35s
This is from a google surch
I was standing at the staging area and watched it go by, the wing was held on by 2 small bolts either side and the bracket looked like 1mm alloy.
I would hazard to say that there may be a bit more strength in it next time out.
But there is no reason any of the EVO's can't run a cyber rear wing and front bar. That plus mega HP will make a quick car. The only real aero restriction I can see from past events is the rear bootlid and the front guards (which limit the tyre size).
Exactly, but you know come a big accident it is going to blow back that way. You hear it all the time "the scrutineers let it run". There are plenty of good fabricators, and cage builders out there but you wonder what would happen to some of the cars if they went in at turn 1 Skaife-Winfield Commodore style etc. You prey another Todd Wilkes isnt on the cards as some of the cars have nothing structural forward of front suspension pick ups and you have to wonder how they would go in a big off doing sub 1;35s
I think all pro cars bar the cyber evo have pretty extensive cages. But it wouldn't be pretty if the cyber car went in hard
I remember reading somewhere that the Cyber Evo wouldn't conform to any regulations for any form of racing, it's that sparse on for safety......
In regards to Clubsprint, it's a joke they can do 39's. There should be no aero allowed and they should all be factory bodied. Call if Production if you must. Even the aero in Open will be over the top this year, and dangerous as everyone is hell bent on weight reduction. That Evo wing fail won't be the last over the next few weeks...
The lines between classes is becoming greyer every year.
my 2 bobs worth!
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
