  • Replies 742
New suspension is amazing. Was carrying a lot more speed through 3 and hayshed (both around 200km/hr through the middle now which is significantly faster than before).
I had a lot more confidence in what the car was doing mid corner to what it was like previous.
It was a good thing but still needs a few tweaks. Was a bit lose under brakes from big stops - but especially interesting into turn 1 and between 11 and 12! :) New wing going on Monday might help that though.
I may have done a 1.43.8 too.
Is anyone going to be posting Vids in here?
Unfortunately I'm out of the country while its on, and after going last year, I'd really love to see some footage from this year.
The website had live timing too I think last year, yeah?
Could have a wet track at times going of the forecast, also the wind speed is high...
Should make for some good driving to watch
http://www.weatherzo...y/eastern-creek
unfortunately that will only mean even less running for the big guns - no point wasting tyres (and the car!) on a wet or damp track...
If it does rain, pray it rains all weekend and you'll see a mad dash on Saturday for the top guns trying to put in one fast lap in the afternoon. Could get quite interesting if they're not used to the circuit in the wet.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
