anyone want to throw a 10 bux in a hat and have a crack at how many engines blow up at super lap?
i say 18
winner takes all or we spend all proceeds on piss and get on it?
It's certainly looking that way with at least 4 engines down in the past 4 weeks across carying classes. Probably more than that given limited info
  • Replies 742
I think a low 28 or high 27 will win it. I've already hear a rumour that the Tilton car has gone faster than Cyber Evo's 2011 time. Could just be rumour but It wouldn't surprise me.
I think some cars in open should really be pro, and we'll see a 33 in open, a few 34s and 35s and the rest spread out in the high 30s and low 40s.
I 39 in Clubsprint is possible too.
There was an EVO doing 1:40 on Saturday at the Creek at a CAMS Supersprint round that will be clubsprint class for time attack and had correct tyres on.
Hence why I predict a 39 is possible. may not happen, but cars are knocking on the door uf sub-40s, which is very impressive on a stree tryre!
I do believe a 39 is there in clubsprint if the track is good and temperatures are right, it is amazing what time attack has done in the last few years to development in supersprint based cars that included open cars. I really need to get my S15 finished but keep devolving new parts to keep up with the competition.
As I said I'll be impressed if it happens. Effectively the only aero allowed under club rules is a big wing so it means most of this time has to come from a combo of good grunt and exceptional pedal skills rather than from some computer generated design that maximizes potential grip.
Anyone have a picture of this EVO?
Yeah I saw the clip of that evo, I recon the driver was sitting a fair bit higher when he got back to the pits. I don't think scrutineers are expected to be structural engineers, only the check basic safety (seates bolted in, fire supression...etc)
Exactly, but you know come a big accident it is going to blow back that way. You hear it all the time "the scrutineers let it run".
There are plenty of good fabricators, and cage builders out there but you wonder what would happen to some of the cars if they went in at turn 1 Skaife-Winfield Commodore style etc. You prey another Todd Wilkes isnt on the cards as some of the cars have nothing structural forward of front suspension pick ups and you have to wonder how they would go in a big off doing sub 1;35s
This is from a google surch
I was standing at the staging area and watched it go by, the wing was held on by 2 small bolts either side and the bracket looked like 1mm alloy.
I would hazard to say that there may be a bit more strength in it next time out.
But there is no reason any of the EVO's can't run a cyber rear wing and front bar. That plus mega HP will make a quick car. The only real aero restriction I can see from past events is the rear bootlid and the front guards (which limit the tyre size).
Exactly, but you know come a big accident it is going to blow back that way. You hear it all the time "the scrutineers let it run". There are plenty of good fabricators, and cage builders out there but you wonder what would happen to some of the cars if they went in at turn 1 Skaife-Winfield Commodore style etc. You prey another Todd Wilkes isnt on the cards as some of the cars have nothing structural forward of front suspension pick ups and you have to wonder how they would go in a big off doing sub 1;35s
I think all pro cars bar the cyber evo have pretty extensive cages. But it wouldn't be pretty if the cyber car went in hard
I remember reading somewhere that the Cyber Evo wouldn't conform to any regulations for any form of racing, it's that sparse on for safety......
In regards to Clubsprint, it's a joke they can do 39's. There should be no aero allowed and they should all be factory bodied. Call if Production if you must. Even the aero in Open will be over the top this year, and dangerous as everyone is hell bent on weight reduction. That Evo wing fail won't be the last over the next few weeks...
The lines between classes is becoming greyer every year.
my 2 bobs worth!
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
