Hi guys
I bought some Mobil 1 engine oil yesterday for $70 5.5L approx. Mobil 1 EP 5w-30.
His name is nick.
If you live in Sydney you can pick it up otherwise he can ship them out to you.
I was pretty happy with the price do I thought I'd share it.
He has some racing engine oils too, they are more expensive though.
He stocks other brands as well like royal purple.
You can search Mobil 1 on eBay.com.au or call him on
0405 509 621
Mobil 1 0w-40 is $100 here is Sydney for 5L but he sells 6 quarts I think 5.5L?? Approx for $65
https://www.sau.com.au/forums/topic/386912-mobil-1-engine-oil/
I normally used castrol edge 10w-40 but 5w-30 is the recommended engine oil grade on 350z manual, so I thought I'd give it ago.
Plus on Mobil and castrolegde website the recommended oil for VQ35DE is 5w-30
I'm not an engine oil expert so I just followed the guide lines online as well as the 350z manual.
What are u using At the moment?
I tried a 5w30 and found it very noisy/tappety. Once I changed to a 10w40 it was much better. I also tried a 20w50 and found the engine sluggish. Whatever works for your engine but I would have thought, in summer especially, a thicker oil is in order.
  • Thanks 1
With respect to scott, the weather shouldn't make much of a difference as the thermostat should keep the engine temp near consistent all year round?
All very interesting, but had to jump in here. I agree in general terms, but the thermostat controls the flow of the water in/out of the radiator to keep the *water* at a consistent temp. There would normally be a correlation between water and oil temp, but it will depend on your driving style as to how closely they influence each other and for how long. Anyway, as we all probably know, the first digit is the cold start viscosity and the second is the viscosity at the benchmark temp (100C?). Can't help but think it's critical to match the second to whatever Nissan say for the motor and not play with it. The first just depends on whether you live in Cairns or Hobart and what season it is...
Anyway, I can't help but think a 5W-30 would be a nice 'sweet spot' for all-year round. 10W-40 would be better at the height of Summer I suspect though. Anyone experimented like Scotty?
Edited by Stuart McK
Been using nick for oil since i got my car, his details are in my stick "servicing", and i been using Mobil 1 5W-30. No ticking or anything... Just check it regularly every 2k so make sure your not burning it as its quite thin oil.
I am going FI soon so gonna use thicker oil , oh and the Mobil 1 filter is bigger and better than stock too so hit that up.
Not exactly.. the 2nd number does specify the viscosity at 100degC, but the first number specifies the coldest pour point of the oil, basically the temperature the oil becomes so think, it can no longer be pumped. Generally the lower the pour point temperature the thinner the oil will be at 'cold engine startup' temperatures, but this isn't actually what the ?W is specifying.
I don't know about anyone else, but I've never been anywhere where it's -18 C, let alone driven a car there. I think 10W X would be fine for most places in Australia according to the above chart.
I love oil discussions - you guys should read the ones that regularly pop up on the Stagea forum.
^^ Agreed, 10W-X won't be a problem for almost anywhere in Aust. Personally I would still stick with 5W30, just because Nissan recommend this weight of oil for all temperature ranges, and just suggests heavier oil 'may' be used in warmer climates.
Japan can get some quite hot summers, so it is not like they haven't allowed for warm climates with their recommendations.
+1 for Nick... Cant beat his prices. And the Mobile EP models he sells dont even exist here in Aust.
In Australian weather unless you live up in the snowy mountains, the first indicator number 5W or 10W is probably the least of your worries. It wont make much of a difference although I would stick with Nissans reccomendation of 5W-30. You should pay attention to the second number because this will indicate the threshold (or close to) of what temperature the oils viscosity starts to break down.
So if you drive your car hard, then go with the 10W-40 (or higher) as it would be a tougher oil. But this doesnt necessarily mean its better for your engine as thicker oils obviously doesnt flow\move as quick as thinner ones which the VQ35 might need hence Nissans recommendation of 5W-30.
Edited by Bourbon Boy
Yes, your right... And so am I.
Oil Viscosity deteriorates the higher the temperature.
So the higher value of the 2nd number, the better the viscosity is of that oil at 100 degrees.
Sorry, maybe I went into to it too much. lol :P
Maybe we are just confusing terms? In my understanding when oil get so hot it starts to break down (deteriorate), it means the oil is failing, it damages the oil and can cause engine damage. I would expect this would be somewhere beyond 200degC..
I am assuming you just mean the oil thins as he heats up? the oil viscosity will continue to reduce as the oil heats beyond 100degC, but I wouldn't classify that as 'deteriorating'.
A little clarity required here.
The first number is the viscosity when cold i.e at cold start. eg 5 weight or 10 weight. Yes thats what the W is for.
The second number is the viscocity at operating temperature eg 30 weight or 40 weight.
So it depends on how "thick" you want your oil at start up and op temp. depending on environment & driving conditions.
It has absolutely nothing to do with the point where oil breaks down LOL.
I'll also let you guys in on a lil secret which has prob been long forgotten.
GW Sougi 6000 if still available is only $80 for 5 litres of pure synthetic and comparable to Royal Purple / Motul etc etc
http://www.skylinesaustralia.com/forums/topic/22458-the-goods-on-oils/page__pid__6169165__st__2460#entry6169165
Edited by mosoto
Oh, and the Sougi S6000 is long gone, but I hear a replacement (X-6000 or something) is just becoming available?
Whilst I tried them on my VQ25det, I went through just about everything and felt that 10w40 was the best feeling... and I think I'll leave it there (re: Commsman's comment about oil discussion in the Stagea section rolleyes.gif)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
