hello all
im looking at moving to NZ and im interested in taking my stag with me. now most will say just sell and buy another, but ive modified just about every part of mine in some fashion so its not really an option. is there anyone on here that can shed some light on importing into NZ for me?? are the rules anything like aus??
any info would br great.
thanks
https://www.sau.com.au/forums/topic/386928-moving-from-aus-to-nz/
The rules are quite easy actually for import into NZ .. basically you can import almost any vehicle you like as long as it's built in in 2005 or newer ... the requirement was 2002 and newer up until the end of 2011 but I doubt you can get the car there today ;-)
I fear that your only option will be to sell the car here in Australia and just buy something else when you get to NZ.
I can clarify a little more for anyone else who needs more information too ... from 1st Jan 2012 you can only import cars to NZ which have a 3 digit emission code, this is the part listed before the chassis type on the build plate in the engine bay.
For example:
E-ECR33 (emission code E)
GF-EC5W (emission code GF)
.. and only cars built to emission standard "Japan 05" will have the newer 3 digit codes and these will be cars built from 2005 onwards.
haha sell your stag and buy my skyline, its sitting back in NZ doing nothing.
i dont know much about importing but NZ is super relaxed on modified cars.
good luck with the move, NZ is one awesome place if you set yourself up right.
No Stag is worth that sort of compliment unless there's white powder in the running boards.
But srsly, is it possible to totally dismantle the 'thing' and send it across as a container of parts? Can it even be complied? Doubt it - forget it!
For example:
Does that apply to a personal import??
NZ don't have a personal import scheme the same as Australia unfortunately. They simplified the rules to only allow newer cars meeting certain standards. There may be some way around it but nothing that I know of myself.
There are exceptions to the standards granted for migrants bringing their cars with them to NZ.
Here's a good place to start:
http://www.nzta.govt.nz/vehicle/classes-standards/exceptions.html
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
