what do you think of the rb26 miata mx5?
72 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hello a few buddies of mine started this project when I met them about 4 years ago ,a RB powered Miata mx5 !!!
at first we installed a rb25 neo motor had to do allot of r&d and we went 9.8 @ 143 in the 1/4 mile. while all that was going on we had been working on a rb26 building it from head.to toe! The car now has a RB26 fully built with a powerglide 2 speed gearbox,GM differential,custom made axles especially for this car from the DRIVE SHAFT SHOP AXLES,a pair of 26x10.5 Mickey Thompson full slicks , Garrett gt42-45R dual ballbearing turbo,c16 race fuel,26psi making over 800hp and 600+ ft.lbs.tq
let me know what you guys think!
this was our 9sec pass On the 5 speed manual gearbox (still had the rb25)
This was our first pass on the powerglide gearbox we didn't know how the car was going to react we wanted to see what it did so we could dial in the launch and everything else after
We were so happy the car did so great on the first pass!!!!! (RB26 set up )the car is capable of doing 8's , the 15th of January we are going to import face off here in SoCal we are definitely going 8's !!!!
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/
  • Replies 48
Hmm thats a very interesting conversion. Its amazing how many different engines have gone into mx5s over the yrs. I personally would've gone a TT Lexus quad cam. But hey each to thier own :)
Edited by Raysboostin
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6173737
This is another video we went 10.1@91mph driver let off half a track and step on brakes at the end we were in a class for import face off we didn't wana get discualified lol Edited by nismorb25neo
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6178611
No I wish lol the motor wouldn't have let us put the radiator in ,we wanted the radiator to fit and not have to cut the crap out of the front so we cut 3" off the firewall to make it fit better,and it actually worked out very well and were very happy with the outcome! The 15th of this month is import face off here in SoCal,hopefully we can hit the 8's,were very excited about it! Its been a long journey to be where we are now alloy if sleepless nights and R%D. I will be posting up the videos for sure for you guys entertainment!
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6181828
No I wish lol the motor wouldn't have let us put the radiator in ,we wanted the radiator to fit and not have to cut the crap out of the front so we cut 3" off the firewall to make it fit better,and it actually worked out very well and were very happy with the outcome! The 15th of this month is import face off here in SoCal,hopefully we can hit the 8's,were very excited about it! Its been a long journey to be where we are now allot of sleepless nights and R%D. I will be posting up the videos for sure for you guys entertainment!
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6181984
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
