Hey,
Trying to keep temps down so would like to try a stock fan from a rb25 or rb26.
Currently have 2x 12" elec fans on a cheap alloy radiator, after i few hard mashes of the throttle, temp slowly rises.
Now,
Im just wondering what the differences between the two are?
I mainly interested in how far the fan protudes off the motor (i have minimal room between motor and radiator)
But any experiences with either fans accepted.
Thanks,
Dan
https://www.sau.com.au/forums/topic/386961-rb26-vs-rb25-clutch-fans/
It will be the cheap ally radiator mate, I replaced mine with a stock GTR radiator and never looked back.
I was also running 2x thermo fans on the front (no aircon) as well as the engine fan.
Sorry, can't help with fan differences.
I found the cheap ally rad just heatsoaked horribly, after about 20mins on the highway the temp would start steadily climbing. Burnouts would get it hot enough to spit coolant everywhere.. put the GTR rad in and I could drop a 1-2min skid without throwing any coolant, temp never got over 105deg and would cool off reasonably quickly.
Something I have noticed with the newer engine fans is the blade count and design, must have been done for a reason :whistling:
Just a thought.. what water pump are you running?
i have a cheap alloy rad on mine no over heating issues, it dropped the temps and i had a GTR rad in there with 2 fans on the front, i still havnt put the shroud on either and its still sits below stock...... on another note my mate just had a similar problem for the last cupple of weeks wouldnt run right on startup sometimes and then slight heat issues at the track similar to your problem needless the say cyc 5 filled with coolant at the last track day so early days but dont rule out a head gasket issue
I wanna see where this goes. I experience occasional overheating in traffic.
Found this:
http://forums.nicoclub.com/omg-my-rb-is-overheating-writeup-t262601.html
I have a built RB26 in my GTT. Does anyone know if the stock clutch fan for a RB26 will fit?
FIT THE STANDARD FAN (the stock fAN AT 1500RPM WILL MOVE DOUBLE THE AIR ANY ELECTRIC FAN WILL.
same height.
32 gtr is straight blade and noisy. 33 and on is better.
This man speaketh the truth.
The stock fan will blow a veritable hurricane through your engine bay compared to thermos.
Been there done that. :down:
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
