Hi Guys,
Earlier today i was driving around, decided to give the car a bit of a run off the lights.
Changed into second while in second around 5000rpm it felt like i had hit the rev limitter, the car lost all power and was blowing a hell of a cloud of white smoke maybe with a tinge of blue out the rear when under load.
I decided to drive the car home, noticed that it wouldnt make boost, boost would go up to 0 psi. When i got home i popped the bonnet and had a look noticed that a fair section of the gasket between the turbo and the dump pipe was missing.
So i thought before i go thru the effort of removing the turbo since its like +35* outside i would see what peoples opinions where.
Note: S2 R33, Stock turbo, running about 12psi
<br />Why does stupid Nissan put plastic/ceramic wheels on their turboes to save cost on such a critical component??<br />
<br /><br /><br />
What the hell made you think it was to save cost? It was to save weight, pure and simlpe. And it was rather successful too. Against OEM equivalent turbos of the time, the rotating aseembly of the first ceramic turbos was a lot lighter than a stainless turbined unit. And then the plastic comp wheel was just extending the theme.
For an OEM application, with an expected lifespan on the road in Japan of <10 years, they were perfect.
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
