I have all this gear lying around that needs a new home.
Note: * = items photos are refference, but may not be exactly the same.
1. Pivot 3 Stage Shift Light (Ssl-Pro)
The Pivot shift light is a great little unit, it can be set at three RPM points, when all three are lit the unit will flash until you shift gears. These are now discontinued and hard to come by I believe.
$130 ono
2. Greddy Style Forward Facing Plenum suit RB25
Thinking about going a larger throttle body, this plenum has been made to utilise the standard throttle body. No fittings are included with it but they have been tapped/drilled.
$300 ono
3. Greddy catchcan*
New, no use for it.
$100
4. Nissan Skyline R33 bootlid
White in colour, has holes for spoilers etc straight, could use a fresh coat of paint.
$50 ono
5. HKS RB exhaust cam gear*
Bought a new set of gears, no longer need this one. still on the car, will take it off in a few days.
$ 150 ono
6. HKS RB timing belt*
Camgear was purchased and intsalled in 09, I presume the timing belt was done at the same time ( I have old receipts that came with the car). Would be lucky to have done 20,000km during that time. Still on the car, will take off in a few days.
$60 ono
7. Blue streak Stilletto 235/40/18
60-70% tread left, good to have as a spare. I have no use for it at the moment.
$60 ono.
8. Skyline R33 OEM radiator
Upgraded to a bigger unit
$50 ono
9. Nismo and Buddyclub gearknobs
Great condition, Buddyclub is barely used
Buddyclub is rare in the Nissan/Mazda thread pitch (M10x1.25) it took me over a month to find one overseas
$60 each
10. RB Hybrid intercooler cross over pipe
No use for it, as I'm going forward facing plenum. 2 1/2 inch ID.
$50 ono
Located in liverpool region, NSW.
Will ship at buyers expence.
PM me!
Adam.
  • 1 month later...
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
