Hi gangs... Just want to vent my frustration, less than 6 months a go i changd my clutch to one of the reputable clutch company that everyone praised about in australia, got it installed from a reputable workshop in the west of melbourne..clutch did not last, slips after 2 months of driving it (not because i trashed it hard), got it returned had to pay for new plates as apprently when it was installed its got oil traces on it and its contaminated.. Fork out few hundred dollars and i told him i just want it fix (as the warranty got declined).. I adviced the shop owner to make sure whoever installing the new clutch again to do not put any trace of oil or lube as per instruction of the clutch compny.. These shop owner warned me these clutch compny and the quality of the clutch they make is a " head ache" .. And that if it slips for the 2nd time, they will not accept that its there fault and he actually offered me not to pay for the 2nd labour but i insisted i will pay anyway providing its not goin to get contaminated.. And he said that there workshop knows how to install these clutch As they have had it installed before with other cars but insisted again that its a "headache clutch".. Now, 3 months later, after babying the clutch, not attempted to even slightest trash on the clutch, and what do u know? Its SLIP badly again.. I just spent a lot on it.. Im soo pissed about it..I felt i got rubbed big time.. by who? I dont know who's at fault, the workshop or the clutch company!!! As much as i want some answers, i dont think i will get that answer as i already know what both side will tel me... Arrrggg... Moving forward, as i need my car every week, im looking once again a new clutch kit and new workshop.. Please anyone help me with reputable workshop close to my area? Im from the west.. And my car is only running -200 rwkw .. Exedy heavy duty button clutch any good for the power i got at the moment? What are the chances of slippage again with exedy clutches? Thank you all in advance..
https://www.sau.com.au/forums/topic/386982-not-really-happy/
I have an exedy cushion button clutch in my car it's an rb20 with over 200 rwkw
I have done a few exedy clutches and never had dramas
That's not to say I haven't heard of it happening just never happend to me
But wat setup are u running on what ?
Exedy HDB will suit your power just fine.
I would look into reasons why the clutch is slipping. Has anybody bothered to look at it and determine why?
You must lubricate the spline on any new clutch or warranty will be void. Its tools who put too much on that need to be shot
. Its a street/daily car .. Stock internal and stock turbo otherwise everything else modified.. Thanks for the in put.. Im
Looking to get exedy this time and fingers cross..
I would certainly get it look at next time when installing new clutch .. But what are the things to watch out for installing new clutches to avoid these mishaps from occuring again? I know shop owners should know there stuff.. Its just that these clutch i got and the company owner told me to avoid lubricating his clutch?? He has a big name and his clutch company name is big in australia even here they promote his stuff in SAU..
When they pulled the clutch out wat there any signs of possible oil leaks?
Rear main or from the input shaft?
No leaks at all otherwise it would have been or visibly all over the clutch plates.. Only thing was the clutch compny suggested when it was returned was, it had sources of lubes around the bearings which to him causes to contaminate the clutch!! ..??
One more thing noticebly, during hot weather (yes temperature), clutch just slip badly almost undrivable all over the gears..Cant feel the bites and just slipsss .. But during early morning or cooler weathers, clutch seems to bite nicely??? No issue whatsoever during cool weather.. Is this normal?
It's recommended that the end of the input shaft has a small amont of grease on it when re-installing... I guess someone may have used to much or possibly the wrong type
As it gets hot it may liquify and get on the plates....
Possibilty....
So you've got a problem with either the clutch maker or the workshop. I dont really understand how a clutch can be a "head ache" so since that sounds strange to me, first guess is its more likely to be the workshop than the clutch maker. So, I would;
1. Find a new workshop. Ask them if there's anything else they typically do when replacing the clutch. It's common to resurface the flywheel, and replace the rear main seal and spigot bearing when doing the clutch, so if they say they typically do that, its a good sign.
2. Give them the history, then ask them to pull out the current clutch and look for any issues with the installation, or the clutch itself, then call you with what they find.
3. Expect to be buying a new clutch. If you go with what the workshop sell, then you have a one stop shop if there's any problems. Any time you buy a part from one place and have it fitted by another, you risk ending up in the situation you're in now, where they blame each other.
I can't conceieve of any reason that the clutch would behave differently with different weather conditions.
I have a feeling I know who you got the clutch from. I had some slippage with mine, but it was rare. When it got rebuilt he mentioned the surface must have had some oil get on it to cause the slippage. My thoughts with mine was that the high clamp forces involved meant oil contamination was more critical.
Shouldnt have any problems with it if installed correctly, you just use the pink lube they give with the clutch put some on the shaft a good amount but not over doing it and must make sure everything is clean clean clean fly clutch check it over and try to keep hands clean when doing it to minimize chances of contamination. Id be guessing its the workshops sloppy work .
Im also confused by the term headache clutch if I ever heard that it would instantly make me question there knowledge. Chasers is in the west and people seem to be happy with there work maybe try them.
Mate clutches really can be a headache even for the best of workshops if they dont really understand the mechanics of it all. Putting oil/lube or anything else for that matter on the spline is probably the worst thing u can do, just look at were the clutch plates sit!!! On the spline!! So soon as u start ur engine centrifigul force will make whatever you've put there go straight up into plates etc. As Joey suggested you only need lube (i prefer a tiny amount of Anti-sieze) on the bush inside the flywheel. Have the guys/shop made sure your pedal has play/travel and is not pre-engaged? Is the clutch assy pull or push? Does the car shudder when you take off? If it does theyve bent the plates on install (another common cock up). It shouldnt be hard to sort out and my advice is if the shop who fitted it cant figure it out get a refund... Who's clutch is it can i ask? If that info is against site rules please dont state. Cheers
  • 3 months later...
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
