So here's the story. I bought an r32 GTST off a guy on these forums. Well, I traded one of my daily car plus cash for it... The car's engine and gearbox are EXTREMELY tight and are probably the cleanest motor/gearbox/clutch combo I've come across (had a 32/s14/s15/180 etc). However, the body needs minor work to make the car immac. The mrs is busting my balls again because I'm back to my speeding ways, and if I lose my license, I essentially lose my job. I put the car on eBay for a quick sale but the guy didn't answer my email's or calls so here I am.
Here are the mods:
-ADJUSTABLE CAM GEAR
-GATES TIMING BELT
-KOYORAD RADIATOR
-STANDARD AIRRBOX WITH STAINLESS STEEL INTAKE PIPE AND COLD AIR INTAKE PIPE TO AIRBOX
-STRUT BAR
-YELLOW JACKET COILPACKS
-HKS BOV RELOCATED TO FRONT BAR
-D1 SPEC CATCH CAN
-ALL WIRING FOR SUB AND AMP IS THERE JUST NEED A SUB AND AMP
-T3/T4 TURBO
-3 INCH TURBO BACK EXHAUST
-GTR INJECTORS 444CC
-GTR RESISTOR PACK
-SERVICED WITH MOTUL OIL AND DRIFT OIL FILTER
-HID'S
-LOWERED AND KYB SHOCKS
-TOMEI PONCAMS
-DUAL STAGE BOOST CONTROLLER WITH SWICTH BUT SWITCH IS NOT CONNECTED
-CLARION DVD HEAD UNIT
-MOMO CORSE STEERING WHEEL
-AUTO METER BOOST GAUGE
-NISMO SHORT SHIFTER
-NISMO GEAR KNOB
-GTR REAR SWAY BAR 24MM THICK
-FMIC
-TURBO TIMER
-CUSHION BUTTON CLUTCH
-z32 air flow meter
Has a scratch on the passenger side, The roof needs a respray, the dash lights flicker (I think the globes are out because they're LED anyway), and Nistune needs a retune
Other than that, the car is awesome. Interior is great apart one from vent, motor/box/clutch are perfect, body is straight, the car goes very hard and drives fine
After a quick sale, will take offers around $6,000. PM or text me on 0488-582-587. Car has rego till Feb but no RWC
I have mentioned all defects on the car so there will be no surprises. Inspections welcome
Edited by stawka
https://www.sau.com.au/forums/topic/386987-r32-gtst-with-a-bit-of-work/
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
