R33 did a total about 12,000km.
Nothing interesting just all standard Corolla A-B duties of shopping, driving to work, driving to my mum's house...
Only interesting bit would be pulling over to overtake several slow cars who are buched up in one go during one of my many trips to Albany (~430km drive).
You end up running that 34SMIC?
I hope to get up to next deca and maybe have a battle with ya Simon :bunny:
Yep been running it for a while now... Previous owner put on a GTR front bar though, so get minimal flow through the sides of the bar compared to the stocky, lol...
PowerFC sitting on my desk here at work, delivered 2 hours ago.
FMIC, Oil Cooler, Bosch 040, Z32, 550cc Injectors are all in various forms of transit towards me as well.
Now to decide between a Highflow R34 Turbo or a 3076R lowmount... Hmmmm
Good work!!! Gotta love knowing you have parts on their way!!
Buy neither. Buy my standard hi flow lol. $500. When you get sick of that skip 3076 and go T51 or something :whistling:
Go the 3076.
Car still going to be daily once it is tuned?
sounds like what i had done to mine, except i had a bad install and going to the manufacter of the turbo in melbourne to get it fiddle with just made it worse (Hypergear ATR43G)
i assume your talking about a Bosch fuel pump? i hear the stock ones are actually pretty ok for power up to about 260KW or so, had a 400 buck Sard one put in but now so broke im thinking of putting the GTR pump that was in there back in and getting a refund on the Sard (mechanic agreed to refund as he didnt actually call and check if thats the one i wanted before installing it)
some say i should just keep the sard if i can afford to..
opinions?
oh and LOL at the comments on la bombas posts, very harsh but couldnt help cracking up a little. Seriously though he messed up his eyes a bit, hope he recovers ok.
Clocked about 5k on my 121, sold it.
clocked about 1,600kms on the r1. For sale.
Clocked about 2k on the gtr.
Gtr in October, was low on oil, spun a big end, cracked the crank.
Was meant to get machine work done through friend of a friend to be faster....
December, get block back, and parts.
Assemble, reinstall, has 672km of run in so far.....
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
