HIKAR1 Posted January 1, 2012 Share Posted January 1, 2012 Hi all, Car: 2004 V35 Sedan Audio: Non Bose with Nav Head unit: The one with flappy door when you load a cd Reason: Sound drops to one side (L or R) when I brake/accelerate (suspected dry solder joint in board) and my beatsonic ipod av cable is also failing so it is irritating me After doing lots of research, I want to clarify one method that nobody ever mention in doing ddin conversion. If i go to g35driver, everybody will direct me to either buy a metra kit or some other more expensive kits. Knowing that the most expensive part of the kit is the A/C control, peeps kept referring to JDM a/c control (separate to audio finisher), since you require to swap out the a/c control as it is a part of the whole finisher board assembly (US spec AFAIK). BUT 99% of V35's in Australia are JDM imports does that mean that our A/C control board is completely separate to the finisher board?? Remove the audio finisher without effecting a/c control?? My aim is to remove the current facia and get a pro to cut a double din size rectangular hole over so I can fit a 7" screen and also to save some money. Is this possible? I guess if it's worth a shot it's worth to diy-it. Link to comment https://www.sau.com.au/forums/topic/387012-double-din-conversion-diy-method-chrisaudio-people/ Share on other sites More sharing options...
Tommy Kaira RL Posted January 1, 2012 Share Posted January 1, 2012 I was going to try this with one of my old dashs. If I was you I would get the kit. The front panel for the AC is powered up from the radio. Unless you can cut a circuit board in half and then work out where to supply the AC circuit. Both the Audio and AC circuits are on the same board and its near impossible to seperate. Link to comment https://www.sau.com.au/forums/topic/387012-double-din-conversion-diy-method-chrisaudio-people/#findComment-6171775 Share on other sites More sharing options...
sonicii Posted January 1, 2012 Share Posted January 1, 2012 The factory AC controls are all integrated into the same single circuit board behind the facia. the double DIN AC controls only come with the double DIN facia units, either Metra kit of the Nissan kit. I believe there is someone who has cut the factory board, but had to wire up a 'birds nest' of cables to get it working. I believe the Metra kit is made in USA, but the Nissan kit is made in Japan, perhaps that is why the G35driver guys refer to it as a ‘JDM” unit. The Metra kit is cheaper, but have heard the fit and colour are poor. I guess you may be able to save some $$ by getting your factory facia professionally cut and buy the Metra kit just to get the AC controls. Link to comment https://www.sau.com.au/forums/topic/387012-double-din-conversion-diy-method-chrisaudio-people/#findComment-6171810 Share on other sites More sharing options...
Chris Rogers Posted January 1, 2012 Share Posted January 1, 2012 that unit I CAN fix. (it is the same unit internally as a 350 Z ) it is a PN2613. if you wanted to find a USDM one you are looking for a PN2615. if you wanted to replace the whole lot with another then you will need teh ENTIRE thing as 2001-2003 are different panels to yours. now given yours is a 2004 the geniune 2DIN bits wil be the go if you want to do it. I can source them if you want or you can do your own homework and get them yourself. Link to comment https://www.sau.com.au/forums/topic/387012-double-din-conversion-diy-method-chrisaudio-people/#findComment-6171820 Share on other sites More sharing options...
HIKAR1 Posted January 2, 2012 Author Share Posted January 2, 2012 Chris, please pm me the available options and prices please. I am pretty dettered from fixing it and prefer tO upgrade. Link to comment https://www.sau.com.au/forums/topic/387012-double-din-conversion-diy-method-chrisaudio-people/#findComment-6172072 Share on other sites More sharing options...
Chris Rogers Posted January 2, 2012 Share Posted January 2, 2012 can do. shoot me your chassis number please. Link to comment https://www.sau.com.au/forums/topic/387012-double-din-conversion-diy-method-chrisaudio-people/#findComment-6172090 Share on other sites More sharing options...
HIKAR1 Posted January 2, 2012 Author Share Posted January 2, 2012 Pv35-450805 Link to comment https://www.sau.com.au/forums/topic/387012-double-din-conversion-diy-method-chrisaudio-people/#findComment-6172099 Share on other sites More sharing options...
HIKAR1 Posted January 2, 2012 Author Share Posted January 2, 2012 Sorry, more complete: 6u90000pv35450805 Link to comment https://www.sau.com.au/forums/topic/387012-double-din-conversion-diy-method-chrisaudio-people/#findComment-6172101 Share on other sites More sharing options...
Chris Rogers Posted January 2, 2012 Share Posted January 2, 2012 3.5 lt sedan 2004 model - got it. Link to comment https://www.sau.com.au/forums/topic/387012-double-din-conversion-diy-method-chrisaudio-people/#findComment-6172222 Share on other sites More sharing options...
Chris Rogers Posted January 2, 2012 Share Posted January 2, 2012 silver panel - non bose. sound about right? PM follows. Link to comment https://www.sau.com.au/forums/topic/387012-double-din-conversion-diy-method-chrisaudio-people/#findComment-6172230 Share on other sites More sharing options...
Chris Rogers Posted January 2, 2012 Share Posted January 2, 2012 Pv35-450805 MODEL :BLJARQYV35EDA-A--- MODEL SERIES: V35 TRANS: 6MT BUILT: 2004/01 DRIVE: 2WD COLOR: QX1 TRIM:G VARIANT: 350GT Link to comment https://www.sau.com.au/forums/topic/387012-double-din-conversion-diy-method-chrisaudio-people/#findComment-6172238 Share on other sites More sharing options...
v35350GT Posted April 29, 2013 Share Posted April 29, 2013 Hi All, any help regarding DD conversion would be great at this point this is what I'm going with.... Metra 70-7550- Wiring harness? Or PAC ROEM-NIS2 - Not sure which one I need? JDM DD Facia - http://www.ebay.com/...6ddc43f&vxp=mtr and the Ca-Fi Dashlinq (Unless anyone can give me any other great alternatives??) Nissan Antenna Adapter Is there anything else I really need to do the conversion? I mean I intend to get Tonkins here in S.A to install it, but is there anything I've missed other than the wiring harness? the JDM unit comes with the A/C controller. Let me know what you think, Also It's a 2003 v35 How can I tell if it's bose or not? or does the $40.00 harness do it anyway? Link to comment https://www.sau.com.au/forums/topic/387012-double-din-conversion-diy-method-chrisaudio-people/#findComment-6831916 Share on other sites More sharing options...
