Does there have to be a challenge? Why cant a thread, or section be started for modelling, just like there is a photography section in SAU forum already and models as they turn up completed can be shown off.
When I was at school we had a modellers club and weekly competitions, which I entred none. Rushing modelling is a recipe for disaster in my opinion.
So if I was to jump on the next challenge with one of my PJR DR's, I'm sure you would be happy knowing they are already on the way huh!
Fair point, what is the general consensus? Just make it a thread? This makes sense to me. Wife, kids, and too many cars doesn't leave much time, even over two or three months.
  On 23/04/2012 at 3:20 AM, coupe72001 said:
Sure thing - just a thread is fine. I'm just very prone to laziness unless feeling competitive is all!
Maybe you can have the honour of being the first exhibitor with your just finished C210 and then we can see what follows eh?
My obsession continues with the purchase of another C210 series Nissan Skyline
1981 MGC211 (MGC210 plated) 2400GT-C2 aka australian spec series 2 with air, steering, 4 speaker stereo and power windows.
Downside is that Headgasket is blown badly, but dropped to mechanics today so should be good.
Edited by Socrates
Also blown head is nothing to sort out. Just be sure it really is the head, and not a pin hole in your timing cover/welsh plug behind timing cover etc. An clean unbroken head gasket will be a bit of a giveaway that there is something else afoot dumping water in your oil.
correct^ head will cost too much to fix.
I'm reconning one of my N47 heads to put on it
now i was told to use the exhaust manifold from the N47 cause it would better suit it?
is that true
  • 3 weeks later...
This is the preliminary Show and shine Classes for the Nationals this year,
Have taken on alot of input from you guys here and looked very closely at the 2010 event and cars already signed up for this year, to revise the Classic classes
these are the bare minimum for the show and shine,
Classes may be split or joined as numbers become more available.
Model - Sub Categories - More Info
Prince - Standard - Depending on Numbers - Includes A & S series
C Class - Standard - Modified - Includes C10, C110, C111, C210, C211
R30 - Standard - Modified - Aus Cars Only
H/DR30 - Standard - Modified - Includes Both HR and DR30
R31 - Standard - Modified - Aus Cars Only
HR31 - Standard - Modified - Includes Coupe and Passage
R32 - Standard - Modified - GTS & GTST Coupe and Sedan
BNR32 - Standard - Modified - Includes Vspec I and Vspec II
BNR32 - Standard - Depending on Numbers - Aus Cars Only
R33 - Depending on Numbers - Modified - GTS & GTST Coupe and Sedan
BNR33 - Standard - Modified - Includes Vspec I and Vspec II
R34 - Standard - Modified - GT & GTT Coupe and Sedan
BNR34 - Standard - Modified - Includes Vspec I and Vspec II
R35 - Standard - Modified
Skyline Mini - Standard - Modified - Pulsar Class
Skyline Wagon - Standard - Modified - Stagea Class C34 & M35
Best Non Skyline TBC
Adrian - what do you mean by A & S series?
See you Wednesday!
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
